14 ultra limited leaking fluid
Old Oct 14, 2017 | 08:31 PM
Black#1's Avatar
Black#1
Stage II
Default 14 ultra limited leaking fluid
has anyone experienced fluid running down their right fork? I'm assuming possibly break fluid but I can't find where it's coming from. After a long ride it will run down the right fork and spray back on my tank and lower fairing like it's from high pressure. Can't find where it's coming from but it's extremely annoying bc it gets everywhere. Any suggestions would be helpful.
Old Oct 14, 2017 | 08:48 PM
jeffro09's Avatar
jeffro09
Fork seals?
Old Oct 14, 2017 | 09:10 PM
sammer4u's Avatar
sammer4u
Originally Posted by jeffro09
Fork seals?
Second the seals. An previous bike I had did the same thing.
Old Oct 14, 2017 | 09:44 PM
cncmike's Avatar
cncmike
Turn your bars to the side and look behind the bottom of the fairing and see if the tops of the fork legs are wet.
Old Oct 15, 2017 | 12:27 AM
ORradtech's Avatar
ORradtech
If it were brake fluid you'd have no brakes and the tank and lowers paint would be ruined.
If the fluid is oily it probably the forks.
The only other thing it could be would be coolant.
Old Oct 15, 2017 | 07:52 AM
1flhtk4me's Avatar
1flhtk4me
Check for excess grease on the bottom triple tree/steering bearing area.
Old Oct 15, 2017 | 08:34 AM
Hammz's Avatar
Hammz
Won't be any excess grease. Rushmores ('14 & later baggers) have a different front end & no grease fitting.
Fork seal.
Old Oct 15, 2017 | 06:51 PM
Black#1's Avatar
Black#1
Stage II
Thanks everyone for the advice I will be checking to see if it's the fork seals
Ultra Pearl
Jun 3, 2018 04:56 PM
laabdog
Apr 8, 2017 06:20 PM
pop1
Apr 8, 2008 08:12 AM
rdrunner
Jun 5, 2006 11:44 AM
HDF Tech
Jun 25, 2005 11:42 AM
