OIL TEMP 275!
Old Jun 15, 2007 | 04:38 PM
Akitakoi's Avatar
Akitakoi
Default OIL TEMP 275!
Is that bad?
Old Jun 15, 2007 | 04:39 PM
glide's Avatar
glide
Default RE: OIL TEMP 275!
It's high, under what conditions did you get those temps?
Old Jun 15, 2007 | 05:17 PM
Arizona's Avatar
Arizona
On a hot day in stop n go traffic you'll get those kind of temps for short periods of time. As long as not too prolongedyou're OK.
This is where synthetic oils come into play, in the most extreme conditions you're OK when such temps peak.
Old Jun 15, 2007 | 05:29 PM
razehog's Avatar
razehog
where is your sender? sound likeyou have a dipstick temp guage?
If it's a dipstick take it out, put the stock back in and get what you can for it in ebay!
I had the same one, I put up with it for about a week.
Old Jun 15, 2007 | 05:47 PM
Akitakoi's Avatar
Akitakoi
I used a deep fry temp gauge. This is after the bike died on me, luckely while I was pulling my driveway.
Harley's premium oil cooler is back ordered, anyone have a recommendation? The Jagg 740-858 says Requires offset oil filter adapter.
What is that?
Old Jun 15, 2007 | 05:57 PM
GlennsGlide's Avatar
GlennsGlide
My 2006 Ultra normally runs about 180-200. On long trips it goes to 120-130 on 90F days which is about 20-30 degF less than before I installed a Jag oil filter adapter and fork type oil cooler. I removed the absolutlely waste of space, waste of money at factory level ambient temp gauge and installed a oil temp gauge in its place which the MOCO should have done.Whoever came up with the ambient gauge needs to be sacked!
Old Jun 15, 2007 | 05:59 PM
GlennsGlide
Sorry I meant 220 - 230degF
Old Jun 15, 2007 | 06:02 PM
Akitakoi's Avatar
Akitakoi
Does anyone know what the "Shut Down" temp is? Must be around 275.[:@]
Old Jun 15, 2007 | 06:20 PM
iclick's Avatar
iclick
ORIGINAL: Akitakoi
What is that?
Last Sunday after a ride in 93° heat through five miles of slow traffic, my SG showed 230° in the pan, the highest I've seen it so far. I immediately went home and gave my PCIII map a shot of extra fuel in the take-off and cruise ranges for some extra cooling, as it was set rather lean (still is, actually). I normally see 180-200° temps while moving, up to 210° in traffic. If I ever saw 275° oil temps I would freak and install an oil cooler pronto. I have the HD Premium installed and it does a decent job of keeping oil temps under control. Jagg makes the HD coolers, and you'd likely be as well off with a Jagg.
The Jagg 10-row looks like a good product, as does the FLH Lowmount, the latter being similar to the HD Premium that fits neatly under the voltage regulator. The adapter fits between your oil-filter housing and the filter, and they also make a version with a thermostat (#4700), which I think is essential.
Old Jun 15, 2007 | 06:23 PM
DocHarley's Avatar
DocHarley
I live in south Fla, My Road King screaming eagle 1550runs 275 degreeson a hot day. I've been told by several HD mechanics that is O.K. Never the less Istillinstalled a oil cooler and now my oil runs around 220 to 230on a hot day. I work on high performance marine diesel engines for a living, the sump oil runs around 220 to 230 degrees. Not sure why I brought that up. lol
