@DynaKid94 I think you're going to be extremely happy with the RWD once you get them dialed in. It doesn't take long, it was a few rides for me. That's what I'm running and I love them. I totally agree with you about hiding them. They're a good looking shock to be hidden. Since I'm going with gold accents I added gold washers from IMZZ and black ARP bolts. It really cleans it up. Even though they're hidden it still looks good when the bags are off.
Definitely digging them already - will definitely take a few long rides to get them dialed in but already a substantial difference. Love the height and the ride quality itself is super comfortable compared to stock.
Originally Posted by twincam10353
That king is lookin rad! You were able to run 14" shocks with that full-length Thunderheader? You aren't getting any contact at the rear axle nut?
You can just grab a kickstand block to stand your bike up straighter.
Thinking block, or someone mentioned that they make an extended kickstand for bikes that sit taller - had the block on my low rider and it did the job. I had just a tad of rubbing when the shocks were fully extended when I was putting them on. On the ground seems to be just fine. I think the actual full thunderheader system would probably clear them better - mine is just the stock head pipe with a slip on and crossover plug.
you might wanna source a coating for those black bolts, when I questioned IMZZ about them they said its just the standard ARP black oxide coating and I know that will rust. I considered Cerakote but ended up going polished stainless.
Thanks for the advice. I'll definitely keep an eye on them for rust. Certainly not something I thought about.
The ARP bolt heads will rust due to the fact that you will marr the finish during installation with a socket or wrench.
Best thing to do is preventative maintenance. After I wash my bike, I just take a few extra minutes to spray a very small amount of metal protector on my bolt heads.
Well, ordered and received the Lucky 13 bars.....no go. They just dont feel right.
Im going to do some research this weekend and hopefully get something ordered. May end up doing a bar/riser combo. I prefer something pretty narrow and around 16. Now just need to decide on one........
Just cut off an inch or so from each side of the bars and re-notch the right side for the TBW, I like narrow bars too and that's what I've done in the past.
I sat on an identical RKS before I bought mine that had the lucky 13's and I didn't like the pullback, felt too close to me, though I am a bigger guy...
I went with the 14" San Diego bars without the pullback and I've been really happy with them FWIW. Only reason I didn't go up to 16's was because I didn't feel like dealing with changing the brake/clutch lines. I have the OG West Coast Tbars on my dyna that are 26" wide, personally I think they would be too narrow on the RK but that's just me.
Ill be internally wiring these bars so cutting an inch off is out of the question.
10/4. Im thinking of the San Diego Bar next and I may even order a bar/riser combo and have to eat the shipping to return the one I dont like. I may just eat the bullet and replace my brake line and clutch line now too.
Puglia, any luck on that brake line?? Might be in the same boat on my front brakes. Im really hoping it doesnt require a visit to the dealer.
