Labor Cost for Clutch pack kit
Old Dec 12, 2017 | 07:07 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
I posted an answer on a different thread. Here's another scenario, suppose the splines are stripped on the shifter shaft going into the transmission. An indy will sell you a shift pawl assy. and that will require to go into the trans. from the right side and top ($$$). I didn't scare you did I? I've been there, if it's just the little seal around the shaft then the price seems right. Good luck.
Old Sep 26, 2019 | 11:16 PM
Anthony Koppi's Avatar
Anthony Koppi
Stage I
That Parts Finder website is solid gold. Thank you for sharing that.
Old Sep 27, 2019 | 03:21 PM
CSMHOG's Avatar
CSMHOG
Also keep in mind, a lot of Indy shops have two sets of labor rates. One if they obtain the parts, second if you provide the parts. Reasoning is they make money when they obtain the parts for you. So your labor rate may be higher if you source them yourself.
Old Sep 28, 2019 | 04:43 AM
GOV5's Avatar
GOV5
Good point. Plus, many times they can buy parts cheaper then you can, even when you are getting a 10-20% discount. And they may pass some of the savings to you, or at least keep your TOTAL bill down.
Fungz
Jan 2, 2020 07:31 AM
800screws
EVO
Oct 10, 2016 03:20 PM
dgdamore
May 7, 2014 12:26 PM
faber
Feb 15, 2011 01:41 PM
Clammy
Jun 10, 2006 03:30 PM
