07 siren install problems
Old Jan 10, 2018 | 05:51 PM
Atlantaclassic's Avatar
Atlantaclassic
Default 07 siren install problems
Siren works but it won't go in the area I assume is for it. Plug won't go in and antennae hits.
Attached Thumbnails 07 siren install problems-20180110_172656.jpg   07 siren install problems-20180110_172706.jpg   07 siren install problems-20180110_172711.jpg
Old Jan 10, 2018 | 11:06 PM
Ssitruc's Avatar
Ssitruc
I just installed one, but on my bike it slides in a different spot. Looking at the install instructions, it looks like you’re trying to get it in the right spot... see pics below.
And install instructions, on the off chance you didn’t have them https://serviceinfo.harley-davidson....e&locale=en_US
It looks like it is fitting in there right (logo out). But if it’s just the antenna is hitting the plastic molding, I’d cut me a groove in the plastic, so I could run the antenna and not have it pinched or kinked too tight. The electrical connnector looks like it’s in its slot, just needs the wire routed around the holders.
Old Jan 11, 2018 | 06:27 PM
bigskyroadglide's Avatar
bigskyroadglide
I Cannot tell from your pics (on phone) so image is small, but the area it goes in should allow it to snap in and the wires are in a notch or groove in the plastic. It will only fit one way and it's a beeecth to get it in. Siren faces out
Old Jan 20, 2018 | 03:11 PM
cficole's Avatar
cficole
Your third picture looks correct. The instructions indicate to just bend the wire to the left to squeeze the siren into its slot.
I'm pretty sure I remember doing just that when replacing mine a couple years ago. The old one had died, and, as I found, it had been installed backwards.
FLHGLIDE
Aug 5, 2014 02:52 PM
DBLXX
2014-2024 Touring Models
31
Mar 26, 2014 11:26 PM
MX Mark
Nov 6, 2011 12:40 PM
biz44
Jul 8, 2009 11:32 AM
togfish
Dec 30, 2008 04:19 PM
