Saw what appears to be a charging pigtail on eBay with a part number 99848-09 that does not come up as a valid HD part number. Three photos look like p/n 94624-97B. Is there a cross reference for discontinued part numbers to whatever part number replaced it? Discovered my pigtail nearly cut through, researching for an affordable replacement.
I'm sorry, "3" pin harness? Tender plugs are two pin unless you have something special going on. I've been using the one skratch listed for years. Or making one out of spare connectors from old tenders.
The only 3, or more, pin charger cords I've seen have been for small li-ion chargers that equalize cells.
Both HD part numbers 94624-97B and the new LED 66000005 have three pins, the tender charger only uses the two round pins. I have no idea what the other "hot" blade type pin is for but its there. I started this thread to see if someone knew of a part number cross reference from obsoleted or discontinued part numbers over to updated part numbers, not to start a controversy or what to use instead.
How many pins are on the end of your charger? All the ones I've ever used had two one positive and one negative find one that matches your charger then you're good
my take on it is this. if you don't know what that 'third pin' is for, then you obviously don't need it. so buy the cheap one and be done with it. if you absolutely have to have it, then buy the one off of eBay. it's less than $10. a lot more money than that has been spent on our bikes 'just because'....
