Thank you thread - a bit long
Old Jan 29, 2018 | 11:47 AM
skratch's Avatar
skratch
Originally Posted by cprhed
Back to the forum. And the break through comes from the fine members here once again.
so what was the problem keeping you from starting?
Old Jan 29, 2018 | 11:53 AM
dawg's Avatar
dawg
Damn. You guys rock. Connector under the seat was jammed up enough to wiggle loose. She's running now
Old Jan 29, 2018 | 11:59 AM
cprhed's Avatar
cprhed
Yep, that. Didn't realize there was another connector under the seat. I thought it went straight to either computer or fuse block. Never touched that end of the wire. It was the great folks here that pointed it out. Apparently another wire loom was pressed against it just enough that it pressed the release on the connector and allowed it to wiggle loose when I removed the console.
I was really nervous that I was going to have to start replacing parts in the tank.
Old Jan 29, 2018 | 12:44 PM
SBates08's Avatar
SBates08
Just for future reference, the console does not have to be removed to pull the tank.
Old Jan 29, 2018 | 12:49 PM
HarleyBP's Avatar
HarleyBP
Great job! Interesting process to follow.
Old Jan 29, 2018 | 12:52 PM
cprhed's Avatar
cprhed
I didn't remove it. Just pulled up from tank and laid it on the rear fender still connected. I assume the movement of that wire loom wiggled the under seat connection loose.
Old Jan 30, 2018 | 08:46 AM
cprhed's Avatar
cprhed
Default Finished photo
Here is a pic of it in the garage all done. Too cold and slick to roll it outside.
Old Jan 30, 2018 | 01:03 PM
Campy Roadie's Avatar
Campy Roadie
Originally Posted by hbsoldier3
Now that is a good idea there Brother.
That's the truth! That alone deserves it's own thread.
Old Feb 5, 2018 | 10:40 PM
cficole's Avatar
cficole
Nice job. It's a damn shame you've got no room to work.
Old Feb 6, 2018 | 11:04 AM
OldPhat's Avatar
OldPhat
Well done cprhed, pictures are great, you did a lot of work just to change Bars. Goes to
show you one thing leads to another, it was not just a simple swap out of the Bars.
John
