No engine oil
Old Feb 26, 2018 | 09:49 PM
  #31
Mikesultra's Avatar
Mikesultra
6th Gear
Originally Posted by perki48
5W20...........you gotta be kiddin'
Typed it wrong20w50....sausage fingers
Old Feb 26, 2018 | 09:53 PM
  #32
Mikesultra's Avatar
Mikesultra
6th Gear
Originally Posted by TriGeezer
OMG! And in Arizona! Therefore, since he doesn’t , I’m betting he never filled it all the way when he changed it.
You were right I used 20w50 but only put in 2qrts. Was trying to get ready for 2 months in Arizona and thought I did it right. Didn’t notice for a couple of rides.
It’s never used a drop of oil ever so I don’t always check befor I ride. Think I’ll change that though.
Old Feb 26, 2018 | 09:55 PM
  #33
Mikesultra's Avatar
Mikesultra
6th Gear
Originally Posted by MotoJockey
Give him time....... he's probably out in the garage reading the label on the bottle of 20W-50 motor Oil thinking, "Damn, I was a little off on that one!"
That’s right I did that. Thanks
Old Feb 27, 2018 | 09:33 AM
  #34
sfchief's Avatar
sfchief
All's fine if you're absolutely sure you didn't add enough. If not, take a couple minutes and pull the derby cover and check primary fluid. I had the disappearing oil syndrome on my 09 during a trip and dumped about 2.5 quarts out of my primary when I got home. Crank seal.
Old Feb 27, 2018 | 10:27 AM
  #35
Vernal's Avatar
Vernal
Enjoy your time in Arizona and welcome to the Forum.
Old Feb 27, 2018 | 11:22 AM
  #36
btsom's Avatar
btsom
There is frequently a penalty for over filling (oil coming out the air filter housing and making a mess) just as there is a penalty for under filling (much more expensive). My personal technique is to put in 3 quarts (with a filter change) and run the engine for 3 minutes or so (oil filter now full) and then fill to the half way point between "add one quart" and full. I get to exercise the dip stick several times during that drill and guaranty never calling the job "finished" until the level is VERIFIED being where I want it. If I don't have the time, I don't don't the job. That is from MY 50 years of doing this stuff.
Old Feb 27, 2018 | 11:31 AM
  #37
grbrown's Avatar
grbrown
Wink
My variation, after 50+ years of doing much the same, is to fill to the lower mark on the dip-stick and take a short ride of 20 miles or so. That is normally after doing other service items, so serves as a shakedown and to check all is well. Then I top off the engine oil.
Old Feb 27, 2018 | 05:37 PM
  #38
big- mike's Avatar
big- mike
We all our way of doing things as long as it gets done that's what counts I'm glad you figured it out rather than having a problem with your bike btw I also run mine a 1/2 quart low to keep oil out of my external breather
Old Feb 27, 2018 | 06:26 PM
  #39
leon anthony's Avatar
leon anthony
I am glad nothing was wrong with your motoringcycle. But when you were guess that it might have gone into the Primary that was a possibility It happened to me If the left crank seal goes south the engine oil goes into the primary case.
Old Feb 28, 2018 | 06:40 AM
  #40
Bubba Zanetti's Avatar
Bubba Zanetti
You can bet if you had not put any oil in you wouldn't have made it 1100 miles before the bike let you know about it.
