No engine oil
Old Feb 25, 2018 | 10:55 PM
Mikesultra's Avatar
Mikesultra
6th Gear
Default No engine oil
I noticed my oil pressure low an fluctuating on my 09 ultra. I checked the oil and it was more than a quart low. No smoke or funny noises and no leaks. Bike seems to run fine. I added 2quarts of synthetic 5w20 which is what I use. I’m in Arizona and have put over 500 miles since I got here 2/1. Where did the oil go?
I changed it at home before trailering it here and I can’t imagine I forgot to put oil in. There’s about 1100 miles since I changed it. Where did the oil go? Exhaust is clean no oil residue and it don’t smoke. Could it have gone into my primary somehow? Bad crank seal? Cold the oil pressure at idle is 32psi once warmed up oil pressure at idle is about 15psi but goes right to 36psi above idle. Any ideas?
Old Feb 25, 2018 | 11:18 PM
perki48's Avatar
perki48
5W20...........you gotta be kiddin'
Old Feb 25, 2018 | 11:31 PM
btsom's Avatar
btsom
Another "One and done"?
Old Feb 25, 2018 | 11:34 PM
TriGeezer's Avatar
TriGeezer
OMG! And in Arizona! Therefore, since he doesn’t , I’m betting he never filled it all the way when he changed it.
Old Feb 25, 2018 | 11:35 PM
groupw's Avatar
groupw
Originally Posted by Mikesultra
..... and I can’t imagine I forgot to put oil in.
MotoJockey's Avatar
MotoJockey
Give him time....... he's probably out in the garage reading the label on the bottle of 20W-50 motor Oil thinking, "Damn, I was a little off on that one!"
Old Feb 26, 2018 | 07:37 AM
Brewmany's Avatar
Brewmany
Quite probably.
Old Feb 26, 2018 | 07:44 AM
Noisy Cricket's Avatar
Noisy Cricket
First off, Welcome to the forum. Sorry you had to run into a group of bozos right off, most of the members are very helpful. I would suggest draining and re-filling with the recommended oil weight and ensuring it is at the correct level, then run it for a hundred miles or so and check it again. That will tell you if you have a leak or you just made a mistake. 5-20 would not be a recommended oil weight.
Old Feb 26, 2018 | 08:02 AM
voodoodrug's Avatar
voodoodrug
did your gas mileage go up? im thinking about running 5-20 high effeciency oil to save gas?
Old Feb 26, 2018 | 08:27 AM
grbrown's Avatar
grbrown
Lightbulb
If you want to save your engine use the recommended oils, as per your manual! Save fuel by riding with a gently use of the throttle - that can make a big difference, especially with the barn-door fairings most of us have. I occasionally ride the German autobahns, some of which have no speed limit - riding at 90mph or so doubles fuel consumption!
