Screamin Eagle Air cleaner install problem
Old Mar 16, 2018 | 10:12 PM
Hammertime1978's Avatar
Hammertime1978
Wonder when they changed it? Mine has 3 bolts and a front to rear bar that connects the front and rear of the air cleaner that says "Screamin Eagle" on it.
Old Mar 17, 2018 | 08:50 AM
Danny Roy's Avatar
Danny Roy
5th Gear
it s not the same model
but i really like to have screw!
Old Mar 17, 2018 | 08:52 AM
Danny Roy's Avatar
Danny Roy
5th Gear
i was think doubole side tape too
Old Mar 17, 2018 | 08:58 AM
Danny Roy's Avatar
Danny Roy
5th Gear
i took picture of my problem you can see the cheap tape inside the chrome cover and the loose it create
Old Mar 17, 2018 | 08:59 AM
Danny Roy's Avatar
Danny Roy
5th Gear
it would have be a good idea to screw it...
Old Mar 17, 2018 | 09:03 AM
Hammertime1978
Slather that pupply with super glue? When I tried to take mine apart (even though it's a different model) when I took the bolts out, I couldn't get it apart because it was glued on.
Old Mar 17, 2018 | 02:40 PM
Cygnusx51's Avatar
Cygnusx51
Yeah there’s two different models, one comes with the fancier air filter with the bracket connecting the front and back plate.
OP, I have the same as yours and the same exact thing happened, like I said earlier. Super glue may work for a while but it dries hard and probably won’t withstand the heat and vibrations. Over time the super glue will crack and flake apart.
Thats why I used the high temp JB Weld. I think the rubber on the filter just sucks at sticking to that 2 sided sticky gasket in the metal trim. I just cleaned it, and the filter, then spread the JB Weld around the gasket. Pressed it into place and let it cure. Put some weight on it to keep the JB Weld from expanding (since it heats up from mixing the two ingredients) and pushing the trim away.
Mine is rock solid now and it should never come apart.
Drtumolo
2014-2024 Touring Models
Jun 22, 2021 06:21 AM
escalade6103
Jun 8, 2014 04:52 PM
murdered1200
Jul 2, 2012 10:11 AM
nightster140
Jan 5, 2009 09:52 AM
primeaus883
May 6, 2008 10:51 PM
