tire wear/ alignment issues
Old Apr 8, 2018 | 02:05 PM
woodthumb2's Avatar
woodthumb2
air it up... forget the 40 psi thing especially if u 2 up or are a big dude... i run 43 rear in my oem dunlops...that will help with the cupping on your replacement... this tire is done...stay away from the longer lasting harder compounds like the commanders.... last longer for sure but no grip...feel every pebble in the road...
Old Apr 8, 2018 | 02:15 PM
Uncle Larry's Avatar
Uncle Larry
Originally Posted by Roadghost
If you have tires worn down with a wavy pattern you have bearing wear. Time to change the bearings.
Have to disagree with this statement.
Old Apr 8, 2018 | 02:24 PM
kel03's Avatar
kel03
Have to agree with u UL, you'd hear the bearings if it were that bad before tire wear.
Old Apr 8, 2018 | 02:52 PM
woodthumb2's Avatar
woodthumb2
yep... or feel the side to side movement or scratching sound in the wheel when manipulated on a jack...bearings do go bad for sure but it is really not that common...90% of the time in my experience, tire cupping is related to air pressure or overloading the bike...or camper...or trailer..or etc... seen it a bunch on front and rear tires in many scenerios
Old Apr 8, 2018 | 03:04 PM
glidein wide's Avatar
glidein wide
Originally Posted by hairymoth
The reason tires often wear unevenly, left side more than right, is because roads are capped (i.e., convex) to shed water to the sides. When you ride straight up on a capped road, you are ridding on the left side of your tire.
Originally Posted by FastHoss
Two words , Michelin Commanders.
That's what I have on mine and suggested to him.
Old Apr 8, 2018 | 03:10 PM
glidein wide
Originally Posted by hbsoldier3
Two words, had them.
Two words, never again.
Why do you say that,what's your experience with them ?
Old Apr 8, 2018 | 03:26 PM
hbsoldier3's Avatar
hbsoldier3
I like them until they get wet, then they slip.
Old Apr 8, 2018 | 07:18 PM
OkieBill's Avatar
OkieBill
Tire cupping is caused primarily from low tire pressure - this allows more flex in the sidewall than engineered, designed, and tested. Google is your friend.
I'm as OCD/ADHD or whatever alphabet abbreviation you want to use but to me, safety items are a no-brainer. The main cause is low pressure allowing flex.
Check before every ride. No exceptions.
Vinnie.
Wheels/Tires
Dec 8, 2020 05:45 PM
bluharley
EVO
35
Aug 30, 2017 03:21 PM
Beach Bagger
Jun 9, 2011 05:14 AM
MotorSgt
Oct 17, 2007 08:45 PM
BERRYP
Oct 13, 2007 10:19 AM
