Can't change from odometer to anything else
Old Apr 23, 2018 | 04:39 PM
Yellow Flame's Avatar
Yellow Flame
Default Can't change from odometer to anything else
I'm the new owner of a '14 FLHR with just over 4,000mi. The problem I'm having is that I can't change the screen from odometer to the other screens. The owner's manual says to use the trigger switch to make the changes. I can't get it to work. Have any of y'all had a problem like this and how did you fix it?
Old Apr 23, 2018 | 07:38 PM
EdwardK's Avatar
EdwardK
Hopefully this is a stupid question but do you have the ignition on? You can push the button with the bike off to get the mileage but you have to turn it on to get it to cycle through the other displays
Old Apr 23, 2018 | 07:51 PM
Cygnusx51's Avatar
Cygnusx51
If it’s shot, you’ll need a whole new left switch pack.
Old Apr 23, 2018 | 08:32 PM
hbsoldier3's Avatar
hbsoldier3
That is what happened on my 14 FLHTK. Would not advance, replaced under warranty at the dealer.
Old Apr 23, 2018 | 09:07 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Old Apr 24, 2018 | 07:58 AM
tpcowfish's Avatar
tpcowfish
Left switch pak, mine went bad too. 14 tk
Old Apr 24, 2018 | 10:50 AM
Yellow Flame
To Edwardk..I had the ignition on. Tried it both ways. But hey.. I'm not above not having the switch on and wonder why something doesn't work. Thanks for the reply. To you other guys... it looks like I'll need to order a switch. Thank you all that replied. I need all the info I can get. I appreciate it. About how much will the switch run. I think I can install it myself.
Old Apr 24, 2018 | 10:59 AM
hbsoldier3's Avatar
hbsoldier3
More than you are going to like. I would just bite the bullet and get the HD lighted switches for around $200.
https://shop.outpostalaska.com/OEMpa...SWITCHES,_HAND
Old Apr 24, 2018 | 11:55 AM
Yellow Flame
Thanks hb. I think that's just what I'll do. I appreciate the input. Ride safe.
tpcowfish's Avatar
tpcowfish
That's what i did, and it has a warranty, or mine did from the dealer i bought from
