Screaming Eagle ??
Old Apr 26, 2018 | 03:16 PM
FL_Grown87's Avatar
FL_Grown87
5th Gear
It's is def a 02 Electra glide standard FLHT. I know the previous owners added items to the bike when they owned it.
As for the filter I did use a air sprayer to clean out the filter and not much came out of it. And when I'm talking about struggling I meant the bike it self. I can hear the air being sucked through the filter.
Tuning the carb I have no idea how to do that.. I'm familiar with Fuel Injection engines. (lol) The bike was idling really low, so I did turn up the idle screw to around 950ish..
Old Apr 26, 2018 | 06:24 PM
hattitude's Avatar
hattitude
Originally Posted by Magnut1
Sentence structure is a little whack on OP original post but I took it as he went to clean the filter and it was clean, that is why I went right to the tune
I thought he cleaned the Carb, that's why I went right to the filter....
Well, it sounds like the filter is clean and NOT over-oiled....
Make sure the air cleaner is installed properly and the correct part for the carb. This could be the issue:
"The early Heavy Breathers were not properly cast/vented for the carburetors. If I remember correctly it either blocked or pulled a vacuum on the carb. vent or a port. That was a long,long time ago, but we came across it early on."
What do the plugs look like? Has it been running rich?
I'd make sure to rule out any other cause before retuning.... it would suck to mess with a well tuned carb, when the cause is something else.. you'll end up just masking the real problem and probably not be able to get it running right...
If you need to tune the carb, and it's an OEM CV40 carb, it's pretty simple.
Read here: https://cv-performance.com/instructions-guides
Old Apr 26, 2018 | 09:09 PM
Ed Ramberger's Avatar
Ed Ramberger
NEVER use compressed air on a K&N style filter - you will blow holes in the media.
Old Apr 27, 2018 | 06:48 AM
Hecklerboy's Avatar
Hecklerboy
Is it me, or does the filter look black and dirty. If it was cleaned properly shouldn't it be red from the K&N oil.
I don't believe blowing it out will work because the oil traps the dirt in the cotton media.
I would buy a K&N cleaner kit and clean the filter properly with the cleaner and water. Always flow the water from the inside out. Let it dry for a day and the oil it correctly.
I've been running a Heavy Breather for 6 years and mine has never looked that dirty.
Old Apr 27, 2018 | 11:51 AM
todd-67's Avatar
todd-67
I am running that same intake and it is noisy. I also get a lot of reversion coming through it but I also have a built motor.
eglideic
13
Sep 6, 2016 04:00 AM
Steel Steed
Jun 20, 2011 06:02 PM
J-Train
Exhaust System Topics
Sep 1, 2009 09:51 AM
harleyflo
Jun 26, 2007 10:14 AM
FlashBang
Dec 6, 2006 12:06 AM
