03 Road King Fork Lock Seized, help...
Old Jun 22, 2007 | 07:55 PM
birdwatcher II's Avatar
birdwatcher II
Default 03 Road King Fork Lock Seized, help...
I've done a search and read this has happened to other RK owners. Does anyone know how to "unfreeze" the lock so I can get it to a dealer? I can't move it, stuck in the driveway and I can't imagine what it would cost me to get it transported to a dealer. Any ideas?
Old Jun 22, 2007 | 08:14 PM
thebiker46's Avatar
thebiker46
Default RE: 03 Road King Fork Lock Seized, help...
You may have tried this..... try pushing the handle barone way while trying to turn key....then the other way.....maybe too much pressure holding the pin from releasing....hope that works...good luck....just might need some lube when you release it..
Old Jun 22, 2007 | 08:18 PM
birdwatcher II
Thank you for the info. Yes, I did try that and there's just not enough play in it to move much. The dealer recommended I spray WD40 in the lock...that just made a mess. Any other ideas? I just got the schematic off Bikebandit.com http://www.bikebandit.com/partsbandi...dept_id=511402 Looks like if I take the Nacelle off, I should be able to get to the lock. From there, I'm wondering if I can get the lock free??? Anyone ever tried it?
Alex
Old Jun 22, 2007 | 08:55 PM
Sol's Avatar
Sol
Had to turn the key with pliers to get my fork lock unstuck. Quit using the fork lock after that...
Old Jun 22, 2007 | 08:57 PM
amstaffs's Avatar
amstaffs
i had the same thing happen to me in myrtle beach you can remove it pretty easy if you need help lety me know all you need is the 8 in 1 tool and a set of allen wrenches
Old Jun 22, 2007 | 09:01 PM
birdwatcher II
amstaffs
Date 6/22/2007 6:57:25 PM
Sol
Date 6/22/2007 6:55:23 PM
Is it as easy as taking off the nacelle, lock cover and then taking the lock off? When I get the lock exposed, how do I get the lock freed up?
Old Jun 22, 2007 | 09:14 PM
birdwatcher II
amstaffs, just sent you a message to your inbox.
alex
Old Jun 22, 2007 | 10:32 PM
aclass's Avatar
aclass
Happened to the brides 02 RK twice. Once in Myrtle Beach and we removed the lock and bought a new one, happened again 3 years later in a Wal Mart parking lot in Utah, and we live in VA!!!!
Got out the tool kit and went to work, never have put another one back in and prolly never will.
You might get lucky and hold your mouth just right and get it to turn but after fooling with it for an hour solid my patience run out.
Even took the lock apart to try and figure out what was up but could find nothing obvious, inside the lock was nice clean and smooth, with grease of course. I had kinda figured it was where she would wash the bike and get the lock wet but I found no rust or nothing.
Good Luck!
06FLTRI
00FXSTS
02FLHRI
Old Jan 2, 2008 | 07:50 PM
HogBack's Avatar
HogBack
Yeap... have the same problem on my RK... have not used it again.... love that aspect of my shovel, where you can put you own heavy dutylock on the fork lock..... Looked at an 03 a couple of months ago... 2,000 miles and it is on it's 3rd fork lock....
Good Luck
Hogback
rydahog
General Topics/Tech Tips
Jul 27, 2017 06:13 AM
MOSTWANTED
Aug 26, 2013 07:49 AM
chorndawg
May 10, 2012 10:08 AM
Big Peter
May 17, 2008 11:03 AM
biker77
Apr 25, 2007 08:59 PM
