HELP with Zeppelin install
Old Jun 22, 2007 | 09:51 PM
Digger53's Avatar
Digger53
Default HELP with Zeppelin install
Rec'vd my Road Air Zeppelin today. Installed the driver backrest hardware and passenger backrest. I must be doing something wrong because I can not get the seat to go far enough down to install the back screw, it's lacking about inch or so. I have the seat as far forward as it will go and still no luck. Can anyone here lead me to what I might try to get it to fit or what I might be doing wrong.
Can't believe this seat is causing me so much pain....guess not enough working parts!
Thanks,
Digger
07' Ultra
Old Jun 23, 2007 | 02:49 AM
Arvid's Avatar
Arvid
Default RE: HELP with Zeppelin install
I have a Road Zep on my 07 Ultra. Initially the rear screw was a stretch. I had to go over the driver backrest and reroute the cable. I'd start with checking the backrest install, if it doesn't clearly fit into the formed cavity of the seat carcass it won't sit all the way down. Also check anything else you may have added. I added the module for the rear blinkers/brake lights which is under the seat, UNDER the backrest mount.
Arvid
jpweld
May 8, 2019 11:09 AM
CSS899
May 12, 2017 08:12 PM
rsscoggins
Aug 5, 2014 09:33 PM
BugBYter
Feb 8, 2012 06:40 PM
2CMan
Jan 5, 2007 02:50 PM
