Brake peddle height
Old May 13, 2018 | 07:58 AM
PaulRM69's Avatar
PaulRM69
Stage II
Default Brake peddle height
Good morning to all.
I have a 1999 Ultra classic and my only issue with the bike is how high the brake peddle is. It is just not a good spot for a needed quick reaction. After laying under the bike it looks like my only option is to raise the foot board.
I have tried to find a replacement that is adjustable but have not come across one. Has anyone else experienced this ?
Old May 13, 2018 | 08:14 AM
GalvTexGuy's Avatar
GalvTexGuy
It's not adjustable, but DK Custom (forum sponsor) has a brake pedal lever that moves the pedal forward and lower.
http://www.dkcustomproducts.com/exte...-bk-sftr-c.htm
Old May 13, 2018 | 09:53 AM
Neil's Avatar
Neil
Not sure if it will fit or not, but, later year pedals where a bit longer and lower. Much easier than the pedal on your year bike.
Neil
RDMC
Old May 13, 2018 | 09:58 AM
Cygnusx51's Avatar
Cygnusx51
I replaced mine with one from Performance Machine. It was a little longer than stock and is curved so that it sits much closer to the foot board. Made it easier to find with your foot and use.
Old May 13, 2018 | 10:55 AM
Veekness's Avatar
Veekness
Just like anything else, the movement becomes intuitive and natural after a while. That said, if you only ride your bike once every six months, absolutely nothing will be intuitive. But if you ride all the time, pretty soon, it should be a non-issue. But if you find a brake pedal that puts your foot in a better place, go for it...might get a little expensive trying out different ones, though.
Old May 13, 2018 | 11:08 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
If you go to swap meets, you could take yours off and carry it with you for comparison until you find something better suited.
You could also cut and drill your stock one, using some plate steel, to relocate the foot pedal.
Old May 13, 2018 | 01:56 PM
DAVENRINO's Avatar
DAVENRINO
I use this on my 2000 UC and one from Softbrake on my 16 limited. Both are WAY better than stock. I don't have lowers on the 2000 so not sure bout the fit with lowers.
https://www.revzilla.com/motorcycle/...rley-1997-2007
Old May 13, 2018 | 11:10 PM
head's Avatar
head
The original brake pedal from 2002 through 2007 touring models is a direct bolt on swap for your bike. The pedal is much nicer like Neil mentioned. These can usually be found on Ebay on the cheap.
Old May 13, 2018 | 11:17 PM
SnoRider's Avatar
SnoRider
Just google extended brake pedal. There are a multiple options for under $100.
Old May 14, 2018 | 12:41 AM
2AMGuy's Avatar
2AMGuy
Community Influencer
Just a note that if you're buying a used part or one not from a dealer, there is a major difference (not sure of what years) in the diameter of the shaft that comes out of the master cylinder into the brake pedal.
06Roadie
Sep 7, 2018 06:15 PM
rhuff
Aug 15, 2018 11:56 PM
broncobob
Jul 19, 2018 10:34 PM
Droop
Apr 16, 2007 08:28 AM
SMenasco
Mar 23, 2007 02:19 PM
