What's this noise?
Old Jun 24, 2007 | 05:26 PM
Road Glider's Avatar
Road Glider
Default What's this noise?
Got back from ride and have been noticing when I roll on the trottle pretty hardIget a noise that sounds like a pebble or pebblesclanging around inside my fenders. Bike pulls really good and no other issues..
Don't know what it is or where it's coming from.....any ideas? Should I be worried.....could it be some kind of spark knock or something? I stops as soon as I let off the throttle a little.
Thanks,
Old Jun 24, 2007 | 05:49 PM
pittguy's Avatar
pittguy
Default RE: What's this noise?
Either detonation,dont see any type of fuel tuner under your signature,if not read the tranny thread
Old Jun 24, 2007 | 06:06 PM
Road Glider
Pittguy,
I know the "rocks in a can noise" I get it when I lug it so I don't think that's it. Maybe the gas? Although I've noticed it the last couple of gas tank fillsbut fromdifferent gas stations..... 92 octane... Been using Speedway and Sunoco the last couple of times....
How's the engine react with low octane fuel?
Old Jun 24, 2007 | 06:56 PM
Taterdog's Avatar
Taterdog
Try a fuel additive to bump up the octane level to see if it goes away. Shouldn't be getting detonation at 92 octane, but who knows. If it goes away, then you at least know what it is.
Old Jun 24, 2007 | 07:29 PM
StreetGlider56's Avatar
StreetGlider56
Just because it says 92 don't mean it is...
Name brand stations only.. Exxon, Texaco, Chevron,
And we get 93 in Texas...
Old Jun 24, 2007 | 08:24 PM
choochoo's Avatar
choochoo
Well first it is stock or been retuned.
Next before you add any additives, check all the pipes and shields for tightness.
These will give the same sound symptoms.
Old Jun 24, 2007 | 08:50 PM
Lost1's Avatar
Lost1
Engines run hotter in summer, so frequently you'll get spark knock in hot weather on the same gas that doesn't cause detonation in cooler weather.
Drop another gear or two before rolling on the throttle- detonation is an engine killer...
Old Jun 24, 2007 | 09:01 PM
Bryan1724's Avatar
Bryan1724
ORIGINAL: Road Glider
Pittguy,
Every time i put Sunoco 93 in it knocks like a mother. It's the Damn ethanol they use in their gas. At one time Sunoco was very good gas, no more. I use Hess when ever possible.
Old Jun 24, 2007 | 09:22 PM
ubreal's Avatar
ubreal
It sounds like detonation I had that on my 07 road king put a SERT on and had it dyno tune the noise went away try two PCIIIs and it was still there the hotter it gets the worse it will get.
Old Jun 24, 2007 | 09:31 PM
Unamed's Avatar
Unamed
You were saying its coming from the fender? If it sounds like the front of the bike you might pull the headlamp trim ring off. theres a little wire clip that keeps it from rattling around. if the clip falls off it rattles like a SOB inside that ring but usually only when your on the throttle.
