Front fork leak
Old Jun 2, 2018 | 10:31 AM
Ultra Pearl's Avatar
Ultra Pearl
Default Front fork leak
Hey guys, I have a leak from the top of my left front fork. Seems to be coming from the seal in the top fork plug, not the top nut.
My question is, has anyone changed these two o-rings and can it be done by just pulling the fork down enough to unscrew both plugs? or does the fork have to come out? shop manual says to remove. I know the plug is under spring tension.
Old Jun 2, 2018 | 10:53 AM
Cygnusx51's Avatar
Cygnusx51
It takes quite a bit of pressure to compress that spring and get the cap screwed in to hold it. I don’t think that’s gonna happen trying to work within the confines of the triple trees, behind the fairing, tank in the way, etc.
Not sure what year your bike is or how many miles you have but it probably won’t hurt to change the fork fluid anyway since you’ll have it partially torn down. It’ll give you a chance to check the fork slider seals also just to be safe.
Old Jun 2, 2018 | 11:03 AM
sanman4ever's Avatar
sanman4ever
Going to have to pull the legs. It's under too much pressure to compress it back in.
Old Jun 2, 2018 | 01:14 PM
Ultra Pearl
Kinda figured that. Thanks guys. 08 Ultra 26000 miles by the way.
Old Jun 2, 2018 | 03:05 PM
run1fsr's Avatar
run1fsr
Yes, needs to come apart, and you're due for fresh fluid too.
Old Jun 2, 2018 | 06:21 PM
08police's Avatar
08police
I took my forks apart to powder coat them black. Its very easy. I drained the oil out of bottom of forks and then you slide the lower off, I replaced the seals and bought a fork seal tool at cycle gear for 40$. Took the top caps off by handle bars and refilled the oil. Make sure you buy new bolts for the lower forks with new copper washers and use an impact to put in. I learned this after one side started to leak.
Old Jun 2, 2018 | 06:47 PM
sanman4ever
You can use the PVC pipe method to press the fork seals in. I've done it many times.
Old Jun 2, 2018 | 07:47 PM
Touten2's Avatar
Touten2
Yep. Done it a couple of weeks ago. New springs while I was in there. Front fork leak-photo550.jpg
Old Jun 3, 2018 | 12:31 AM
vizcarmb's Avatar
vizcarmb
MIght as well rebuild while you are at it.
Good luck
Old Jun 3, 2018 | 04:44 PM
Ultra Pearl
So stripped bike down today and pulled left fork out. Turns out fork plug bolt was just a little over hand tight, must have loosened up some how. Have new o-rings otw so will replace just to be sure. I don't know how you are suppose to torque that plug bolt or top bolt when you can only fir a wrench on there.
