5k fluid change, f*d it up.
Looked around to the primary drain plug, found a couple more drops of fluid. Fu**!! Grabbed the torque wrench, went to max setting, of recommended torque. Wiped everything down, again. Question I have is. Is there any danger of me cracking the primary? Is the primary aluminum like the oil pan? I am sure I did not cross thread the plug, at least I hope not. Maybe I ripped the o ring? Anyways, the bike was hotter than when I changed the fluid and replaced the drain plug, and still got a few more turns out of it before it was torque down. Did I miss something. Is MFT, to tight for this drain plug? I was very careful with the engine and trans plug, because I know the pan is aluminum and the drain plugs are steel. I am just not sure about the primary. As long as I don't strip the threads or the primary, should I just get it MFT (mother f***ing tight)? Help me out guys and gals. Leaving earlier than I would like tomorrow to beat the afternoon high of 98 degrees.
Thanks Dawg.
The primary oil level is checked with bike level(straight up)not on Jiffy.Refill will take 32 to 36 oz. to get to the bottomof clutch spring,dont go higher.
The tranny fluid level is also checked straight up.Do not screw dip stick in to check.
These fluids should be checked with warm engine.
MFT could strip the threads in the aluminumcases!
You are not supposed to check the tranny fluid while the bike is on the jiffy stand. It Has to be standing straight up!
