2014 Street glide - b2132 error code
Old Jun 17, 2018 | 09:34 PM
1207alley's Avatar
1207alley
Stage I
Cool 2014 Street glide - b2132 error code
This just happened today. My bike was sitting in the garage on the trickle changer. I unplugged the charger to move it to a new receptacle, when I plugged it back in, the headlight came on.
When I do the diag research, the BCM shows a b2132 error code. With the switch turn on to high beam, I can clear the code but the headlight stays on even when the ign switch is turned off. I turn it back on, the error code has returned. I am looking for some troubleshooting help. Thanks in advance.
Old Jun 17, 2018 | 09:39 PM
Keithhu's Avatar
Keithhu
You probably have a short somewhere
B2132 is 'high beam output shorted high"
After poking around a bit with Google, it's possible you have a bad low/high beam switch.
Old Jun 18, 2018 | 01:25 AM
mmesa005's Avatar
mmesa005
+1 on what keithhu said about having a short. When I purchased my 09 Rocker the PO put blue leds all over the bike. He had the fuel tank off and when he replaced it he pinched the wire providing power from the fuse panel to the headlight switch causing a ground.
You can get wiring diagrams from Harley's web site. You just need your VIN.
thebestofindica
Jun 28, 2020 03:23 PM
Windseeker
Jun 12, 2019 06:37 PM
USAproud
Electrical/Lighting/Alarm
May 26, 2018 08:29 PM
Crossbones
Jun 24, 2012 07:31 PM
Bigstick
Sep 7, 2011 04:51 PM
