Brake lights stay on.
Old Jul 3, 2018 | 08:49 PM
shurlingj's Avatar
shurlingj
Stage III
Default Brake lights stay on.
'15 Tri-Glide. Started with cruise not working. Came on but wouldn't engage. Then Security light came on and stayed on. Then check engine light came on. Stopped for a while and engine light went off.Left for the 40 mile ride home stopped for gas. Cranked up and engine light went out and stayed out. Got on dirt road to home. Drove 5 miles on bumpy road and about the time I got home the security light went off. Brake lights are still on.
Old Jul 3, 2018 | 09:07 PM
Sparky357's Avatar
Sparky357
One of your brake light switches is open which is also why cruise won’t engage.
Old Jul 3, 2018 | 09:11 PM
ORradtech's Avatar
ORradtech
I would think so as well. The rear switch has a habit of going bad from exhaust heat. Try taking one wire off of it and see if the light goes out.
The front will also stick sometimes. You can usually tell that by the play in the lever.
Old Jul 4, 2018 | 03:44 AM
Japiooo's Avatar
Japiooo
2nd Gear
Check if your front brake lever returns fully after applying the brakes. If not, it will actuate the brake light switch.
If so you need to rebuild the master cylinder, easy job.
I learned a lot from this video on youtube:
Or by title:
HARLEY DAVIDSON 2001 FAT BOY FRONT MASTER CYLINDER REBUILD
Old Jul 4, 2018 | 04:17 AM
grbrown's Avatar
grbrown
A further possibility, if your bike has conventional bulbs, is that the rear/brake light bulb has failed. I have had a couple where one of the filaments has blown and shorted to the other one, leaving them both glowing. So check that first!
NJMadDog
Mar 7, 2015 08:08 AM
Twinrider
Feb 9, 2015 06:14 PM
Cotton Hill
Jul 21, 2011 10:49 PM
Sallyman
Jun 27, 2011 06:12 PM
6speed
Mar 9, 2008 01:01 PM
