Tacchometer backlight is out!
Old Jul 9, 2018 | 09:27 PM
GittinThere's Avatar
GittinThere
Default Tacchometer backlight is out!
How would I get to the blown bulb on my tach? 2003 Anniversary FLTRI RG.
Hopefully it is serviceable...
Old Jul 10, 2018 | 06:02 AM
caulk04's Avatar
caulk04
Well, I'd think that they are LED like mine are on my 08...so not serviceable unless you're comfortable with electronics.
https://www.hdforums.com/forum/touri...or-change.html
Old Jul 10, 2018 | 06:09 AM
GittinThere
I'm surprised that they might be LED back then. But thanks for the link
Old Jul 10, 2018 | 06:18 AM
RANGER73's Avatar
RANGER73
Pull the tach and look at the back, check
for a bulb socket.
Old Jul 10, 2018 | 06:19 AM
GittinThere
Does fairing have to come off to pull it?
Old Jul 10, 2018 | 06:41 AM
Keithhu's Avatar
Keithhu
No, its independent of the fairing.
Old Jul 10, 2018 | 08:33 AM
GittinThere
Thought it was. Just thought the fairing might need to come off to allow access... Glad it don't!
Old Jul 10, 2018 | 08:41 AM
ORradtech's Avatar
ORradtech
The outer faring does come off, the inner does not. If there's no socket for the bulb that you can twist off from the back you'll have to pull the guage and disassemble it to gain access to the bulb which will most likely be soldered to the board. Not real difficult but time consuming small work with a soldering iron.
Old Jul 10, 2018 | 09:09 AM
Keithhu's Avatar
Keithhu
I believe he's on a Road Glide, so no fairing, inner or outer involvement necessary.
Old Jul 10, 2018 | 09:22 AM
GittinThere
Re: Kiethhu, you are correct and it seems to be only the plastic bezel around the speedo and tach that need to be removed. I actually have the service manual that I COULD refer to
It's much more better (hehe!) to interact with y'all than sitting down with a bunch of pages to thumb thru
