any answers?
Old Jun 26, 2007 | 09:45 PM
the big buck's Avatar
the big buck
Default any answers?
i put in a 37g cam in my bagger...dyno results were good...90+hp&trq. but the cam comes on around 4000 rpm and off the line shes a little weak....i have v&h true dual headers and thunderheader slipons....i was thinking a 26g cam and a rb racing 2n1 pipe....any thoughts?...and is running my bike at 4000 rpms bad?
Old Jun 26, 2007 | 10:00 PM
gunrunner's Avatar
gunrunner
Default RE: any answers?
A lot of people do the bigger is better build but smaller duration cams that come on about 2000 and pull to redline and a 2 into 1 exhaust will smoke the other builds anyday. Your bike is set to run top end with the true duals and big cams, both items are for making power at the upper rpm range. Not what most want out of a big twin, It wont hurt the bike as long as its under redline but its not going to be a bull out of the gate till its in its power range.
Old Jun 26, 2007 | 10:08 PM
the big buck
it is a fast runnin bike i mean i spank my buddies stockers its just with me and my wife on and bags loaded it takes a while to get that sweet spot on the cam....will the 26g come on faster and still rev to 4000-5000 or will it fall flat on its butt?
Old Jun 26, 2007 | 10:59 PM
smknflms's Avatar
smknflms
.re-gear..3.37..and it'll come on at the bottom.
Later
Old Jun 26, 2007 | 11:03 PM
Ram's Avatar
Ram
What year and model bagger?
Reason for asking is prior to a certian year they had one primary gearing then switched to what is currently installed.
Unless you know yours is the prior, or has being switched back the 37g won't be asoptimal (with head work too) as the 26g.
I'm planningon changing myprimary gearing from stock '06at3.15, to what H-D used to run3.37 primary gearing and going with the 37g also.
redmosquito1
Oct 2, 2012 02:18 PM
hogkrazy
Exhaust System Topics
14
Mar 28, 2012 05:38 PM
bensonjv
23
May 23, 2009 07:52 PM
HARLEYFLSTSITIM
May 31, 2007 11:09 PM
the big buck
Mar 16, 2007 08:23 AM
