I have a Stock 07 Road King Classic with Jones slip-on Mufflers and Vance& Hines Fuel Pack.I recently have been experiencing while riding my Rpm's will not come down or increase on its own with out touching the throttle. I can sometime shut the bike off and restart and everything is fine.
I'm baffled. Shouldi reset the ECM?
deleted original reply because of multiple post...... IAC also may need cleaning as another mentioned
i assume your bike has throttle by wire?
Turn the RUN switch to RUN, do not touch the throttle.....
Turn on the IGNITION SWITCH, wait for the CEL (Yellow engine light) to turn OFF....
Turn off IGN only... wait for about 5 seconds then turn on 5 seconds then off again 5 seconds and repeat this sequence 3 more times..... also once this resets make sure once your done riding that you allow the bike to idle to normal before shutting down. I always use the ignition switch to shut mine down also once i see my rpms go to normal idle... if your bike isnt TBW then this procedure wont work
Well I cleaned the IAC Module. Took my bike for a ride and everything is back to normal. I just want to thank you again for your help.
Safe Travels!
Best Regards,
Pete
