Key wont lock ignition switch
Old Jul 27, 2018 | 11:15 AM
Bikerpipes's Avatar
Bikerpipes
Default Key wont lock ignition switch
My key don't lock the ignition switch on my 2012 ultra I bought bike used from Harley dealer it has security fob but someone could turn it on and run battery down can dealer make me a key.
Old Jul 27, 2018 | 11:17 AM
mmesa005's Avatar
mmesa005
The dealer should be able to make you a key or replace the switch/fork lock with a new set/keys.
Old Jul 27, 2018 | 11:21 AM
cncmike's Avatar
cncmike
The dealer can order any Harley key if you show him your registration with the vin. They have strict rules about ownership
Old Jul 27, 2018 | 11:39 AM
HogglyWoggly's Avatar
HogglyWoggly
Does your current key lock/unlock tour pack or saddle bags? If so then it seems to me as if your switch is either hosed or has been replaced. Either way, if you order your key based on the number under the plastic cover then its not going to work either. You'll need to replace your switch based on the key number.
Old Jul 27, 2018 | 11:54 AM
kyote's Avatar
kyote
Plus.. the dealer should replace at no charge.
Old Jul 29, 2018 | 08:55 AM
TOMMAY's Avatar
TOMMAY
You probably already know this, but on mine the only way to lock the ignition is to lock the forks. Forks all the way to the left, key all the way to the left, depress and turn key to lock and remove.
Old Jul 29, 2018 | 09:50 AM
Bikerpipes's Avatar
Bikerpipes
I did not know this thanks.
Old Jul 29, 2018 | 10:00 AM
Bikerpipes's Avatar
Bikerpipes
I tried that fork locked but you can still turn on ignition.
Old Jul 29, 2018 | 07:43 PM
markwolula's Avatar
markwolula
I wonder if the previous owner had the ignition switch out at one stage , and did not align the tumblers correctly when installing ignition switch back in, which in turn stops the locking mechanism from working ???
You can go through the exercise of removing the ignition switch and then re align the tumblers down the shaft , (videos on the internet).. Then re install switch , and see how you go ….It can be a pain in the butt if it is your first time...
My advise is,, go to dealer and get them to remove ignition switch and align tumblers , (if needed), with there aligning tool, and see if that rectifies the problem..... If not you may need a new switch mechanism …..
Old Jul 29, 2018 | 08:04 PM
Hoginedgewood's Avatar
Hoginedgewood
You sure you’re doing it right?
