Clutch replacement
Old Aug 22, 2018 | 08:15 PM
jdbenson1's Avatar
jdbenson1
Default Clutch replacement
My 2011 flhtk clutch is slipping after adjusting and wants to slip on long grades at highway speeds.. looking to upgrade clutch and to a heavy spring. Looking for some good suggestions for a replacement.
Old Aug 22, 2018 | 08:29 PM
Veekness's Avatar
Veekness
Same problem with my 2011 FLHX. Barnett Kevlar kit solved it. Used the old steel plates. Used Dexron as per their suggestions.
Old Aug 22, 2018 | 09:19 PM
SBates08's Avatar
SBates08
You can find those friction plates pretty reasonable. You definitely don't want to do the heavy duty spring plate.
Old Aug 22, 2018 | 11:48 PM
Guntoter's Avatar
Guntoter
37807-03 pink dot (165 KgF/ 364 lbs/ft) 2007 thru 2010-103 "Police
The above is the part number and description of the clutch spring that I would strongly recommend. 258 lbs/ft is the stock spring and it's too weak. Try the spring first, alone, and I bet your slippage will disappear.
Old Aug 23, 2018 | 04:52 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
If it started slipping after adjustment I'd suggest starting with the adjustment.
Old Aug 23, 2018 | 06:46 AM
CndUltra95's Avatar
CndUltra95
But, that would be to easy...
Never had an issue with spring tension on the 95 SE kit and spring the spring that came with it.
Btw, how many miles on the clutch and when was it last adjusted or lube changed.
there might be a couple of clues to assist.
Then again if you wanna change for the sake of change...
Rob
Old Aug 23, 2018 | 06:57 AM
Scudda's Avatar
Scudda
Energyone makes a great extra plate and HD spring kit. Just put it in my Fatboy this year
Old Aug 23, 2018 | 10:44 PM
jdbenson1's Avatar
jdbenson1
Rob
well it's a 2011 fly 103. Just adjusted it 900mi ago I just had the competitor updated so this kinda sucks I have to open it up again long trip coming up and don't want any problems so the fellows and I will go through it...... left for upper michigan and got into some long grades and it started slipping.. so I ran 5th for a bunch of the time....
Old Aug 23, 2018 | 11:17 PM
SG-Jay's Avatar
SG-Jay
Plus one for the Energy one extra plate heavy spring kit. I've had no slipping issues with mine since changing it.
Old Aug 23, 2018 | 11:28 PM
Stingray702's Avatar
Stingray702
I was having some clutch issues with my Rivera Primo setup. Went back to a chain primary. Bought the Baker 9 plate street performance clutch. It's pricey, but AMAZING! Couldn't be happier!
