Header pipe, 2000 RK
Old Aug 22, 2018 | 08:30 PM
Casper's Avatar
Casper
Default Header pipe, 2000 RK
Saw a 2003 RK with a header pipe that the cross over went under the frame, like new bikes.
anyone know of a exhaust that will fit my 2000Roadking, eliminating the “Y” pipe on rear jug?
thanks
Old Aug 22, 2018 | 11:57 PM
Guntoter's Avatar
Guntoter
S&S Power Tune Duals. However, that cross under pipe hangs lower than on the '09 and later bikes, lessening clearance. Also, the bracket for that pipe mounts to the transmission pan bolts at the rear so if you are using a stabilizer bracket that mounts there (like the Progressive kit does) then it will not work, or you have to eliminate the stabilizer.
Old Aug 23, 2018 | 12:43 AM
Casper's Avatar
Casper
Thanks Guntoter
GregGillette
Exhaust System Topics
Jan 29, 2017 09:44 PM
apetterez
Shovelhead
Oct 3, 2016 12:44 PM
Djcamis
2014-2024 Touring Models
Dec 25, 2015 02:28 PM
chiefparry
Sep 8, 2009 11:28 AM
ckamin
Mar 10, 2006 07:53 PM
