Security key stays on
Old Aug 28, 2018 | 10:02 PM
Mapabrown's Avatar
Mapabrown
Stage III
Default Security key stays on
We bought a 2006 HD Ultra Classic Touring bike. The security key light stays on, no odometer reading, spedo, tach, blankets, brake light, or horn now work. We've tried basic override systems & fob fond without success. Any help with this is greatly appreciated. Bike still runs great, except above problems. Thank you!
Old Aug 28, 2018 | 10:47 PM
Vernal's Avatar
Vernal
Welcome to the Forum from Utah.
check your accessory fuse, I believe it powers the circuits your having trouble with.
Old Aug 28, 2018 | 11:09 PM
Mapabrown's Avatar
Mapabrown
Stage III
Thank you! He's gone out to check it as we text! Thanks for your quick reply!
Old Aug 29, 2018 | 07:20 AM
nutsandbolts5212's Avatar
nutsandbolts5212
You are going to need a new TSM, just fixed the same problem on a 2007 Softail. Get the service manual for your bike, troubleshoot, and double check, but I'm 95% sure in my answer. About $300, and I wouldn't buy a used one, personally. My 2 cents, good luck!
Old Aug 29, 2018 | 08:00 AM
Keithhu's Avatar
Keithhu
I imagine thats *a* reason, but not necessarily *the* reason. The key light staying on is indication of an electrical fault somewhere - pinched wire, etc.
Old Aug 29, 2018 | 11:27 AM
nutsandbolts5212
Why I said to get the manual, troubleshoot, and double check.
Old Aug 29, 2018 | 12:33 PM
Mapabrown's Avatar
Mapabrown
Stage III
It was the fuse!!! Thank you to all who replied! Great forum & much appreciated!
Old Aug 29, 2018 | 12:48 PM
Keithhu's Avatar
Keithhu
Well, fuses blow for a reason. Do you know why it blew?
Old Aug 29, 2018 | 01:02 PM
Vernal's Avatar
Vernal
Glad it was an easy fix, let's hope it doesn't blow again. Here's a couple pages from the 2004 Electrical diagnostic manual. It explains how to pull the Diagnostic Trouble Codes on the bike. They help you pinpoint a problem. This link lists them too. https://www.fuelmotousa.com/p-29661-...es.html#pcodes
I would also check the connections on the horn make sure they are tight and clean and try the cigar lighter and see if it works. Those are two things that could cause excessive current through the fuse.
Here's a good video on how to retrieve the PIN that is in the bike now:
https://video.search.yahoo.com/searc...13&action=view
Old Aug 29, 2018 | 01:22 PM
Vernal's Avatar
Vernal
You mentioned having a fob. Do you know the PIN number? This may be in the owners manual:
