max. pressure in shocks???
Old Jun 30, 2007 | 12:34 PM
jrbean1's Avatar
jrbean1
Default max. pressure in shocks???
On stock air shocks what is the max air pressure? I have a 04 road king if that should make a difference.I know everyone likes to have different pressure in them. Just want to know so I dont blow out the shock. I will be using the hand pump from HD. That is a neat little tool to have. Waiting for my service manual to come in.
Thanks
Jrbean
Old Jun 30, 2007 | 12:39 PM
gambler's Avatar
gambler
Default RE: max. pressure in shocks???
Your owners manual should list the safe pressure range. I wouldn't go over 40 lbs. I usually put in 35lbs when riding 2 up.
BluRooster's Avatar
BluRooster
http://www.hotbikeweb.com/tech/0608_...le_suspension/
Old Jun 30, 2007 | 01:03 PM
Arizona's Avatar
Arizona
The air in those shocks is a very minute amount as far as volume, so that tiny H-D pump works well. A regular bicycle pump would probably burst then system unless you were VERY cautious. I keep mine at 30 pounds on my '05 E-G (i'm 235 lbs) and run the bike minus the tourpack most of the time except for road trips.
Old Jun 30, 2007 | 01:14 PM
SoCal_Pappy's Avatar
SoCal_Pappy
??? Well when I dropped the rear on my '07 RG (with 2 1\2" lowering cam & OEM Air Shocks) - Riding 2-up loaded had to jack up the Air to 65+ to stop from bottoming out.... NEVER had a shock failure??? But the ride sucked!! So changed out to Progressive 440 HD!
Old Jun 30, 2007 | 01:20 PM
jbhawley's Avatar
jbhawley
25# front
35# rear
only 2001-older have front air shocks
Old Jan 23, 2008 | 10:30 PM
AZ RKC's Avatar
AZ RKC
I ride 2 up mostly and keep the air @ 35. Rides great. I am 240# and the wife is 120#
ajclassic
Oct 30, 2017 07:47 PM
Kdub2
Oct 7, 2015 02:00 PM
cobra0375
Sep 23, 2011 11:54 AM
OCCoastie
Apr 4, 2011 08:19 AM
dchoran
Mar 28, 2007 11:22 AM
