Clutch adjustment after cable replaced?
Old Oct 1, 2018 | 06:34 PM
RickK's Avatar
RickK
Default Clutch adjustment after cable replaced?
I will be changing out my stock clutch cable with a +6 cable since I added taller bars. I plan to drive the bike up on a 2X4 so that it will lean a little more on the stand so that I will not lose too much oil. I just changed it about 500 miles ago and it stills has a lot of life left in it.
My question is do I HAVE to remove the left side cover and adjust the clutch afterward or is this just a " while your at it" kind of thing? I don't want to do it if it is not needed. Did you guys make the adjustment?
Thanks
Rick
Old Oct 1, 2018 | 06:44 PM
soulpatch's Avatar
soulpatch
Short answer...yes. It will be by far easier to do it than to not. Just replaced my clutch cable for the 12" mini's I installed. Just for fun, did exactly what you want to do. Couldn't get the damn thing tuned back in for the life of me. I've always told people to adjust it and had a moment of "maybe I'm wrong" and ya, didn't work. BTW, you are going to lose oil in your trans either way. It's a quart, drain it and refill it with fresh once it's done. A 2x4 isn't going to change the angle enough to prevent most of it from coming out anyway.
Old Oct 2, 2018 | 01:16 AM
1Canuck's Avatar
1Canuck
Drain the oil into a clean container and put it back in later.
yes, adjust the clutch
Old Oct 2, 2018 | 04:06 AM
grbrown's Avatar
grbrown
To replace the cable you have to disturb the operating mechanism, as well as setting up the cable once installed, so I agree - yes!
Old Oct 2, 2018 | 04:42 AM
RK_Classic's Avatar
RK_Classic
Take the 30 minutes and do it for peace of mind.
rk classic.
Old Oct 2, 2018 | 06:13 AM
RickK's Avatar
RickK
Ok, sounds like I will be adjusting the cable. It doesn't look like it is a big job to do anyways.
But to SoulPatch's comment, wouldn't it be more than 1 quart? My bike takes 3.5 quarts. Just asking.
Thanks
Old Oct 2, 2018 | 06:19 AM
RANGER73's Avatar
RANGER73
Transmission doesn’t hold 3.5 quarts.
Old Oct 2, 2018 | 06:51 AM
soulpatch's Avatar
soulpatch
Trans is roughly a quart. Primaries vary a bit from model to model. Engines are the same. Make sure to read your manual for the exact amounts and even then don't trust it completely. USE your dipsticks and eyes.
It's not a BIG job, but you still need to follow what you are doing. Fresh gaskets, towels to wipe things out and definitely something to hold parts (especially the three bearings in the actuator). A manual is always good to have, since it'll show you step by step.
Good luck, let us know how it turns out.
Old Oct 2, 2018 | 07:26 AM
bigpappa160's Avatar
bigpappa160
Default Clutch Cable
Thanks
Rick
Yes adjust your clutch in the primary, The biggest job in replacing the cable is taking the transmission cover off, but it isn't hard, be patient! Just did my like a month ago, well I did mine twice, 1st time I put a +6" cable in and it was too long,. Luckily a guy on here had a +4" cable that we traded even and the +4 cable worked. And the board thing I don't think it will work, might work for some people but didn't work for me the 1 st time, just drain and put another fresh quart in.
Old Oct 2, 2018 | 07:45 AM
24v's Avatar
24v
Keep in mind you have 2 separate adjustments that adjust 2 separate parts of the clutch system. The adjuster on the cable is to take up any slack in the cable itself. This is for stretch that happens over time. The adjustment behind the derby cover adjusts the clutch itself and is meant to take up slack as the clutch plates wear down. If your clutch is properly adjusted then you do not need to go into the derby cover and re adjust it. You can loosen the adjuster on the cable to remove it and do the same on the new one to install it. Then adjust the cable like normal.
Also, if you have a bike that has an engine guard and bag guards, you can put a blanket on the floor and lay the bike on it's side. You shouldn't really lose much, if any, transmission oil this way.
