Trouble code 2014 Limited
Old Oct 16, 2018 | 08:03 AM
Basictti05's Avatar
Basictti05
1st Gear
Cool Trouble code 2014 Limited
Saw an odd code show up this week. "V INNER" I could not find a reference to this anywhere in the shop manual. Anyone have any ideas?
Old Oct 16, 2018 | 08:33 AM
memphisharley's Avatar
memphisharley
how old is the battery
https://www.hdforums.com/forum/dyna-...tart-up-2.html
Old Oct 16, 2018 | 09:52 AM
Basictti05's Avatar
Basictti05
1st Gear
replaced factory original in fall 2014, bike is always on a trickle charger when not in use
Old Oct 16, 2018 | 10:51 AM
memphisharley
Have it load tested. I would say 3 years is about the max for retaining cranking amps on most factory type batteries.
Old Oct 16, 2018 | 02:13 PM
user 78082023840's Avatar
user 78082023840
Default code vinner
Did u install a thundermax tuner?If so and you didn't include the vin # of your ride during t-max installation you will get that code.
Contact thundermax and they will have a solution for you.Hope this helps.
Peace and Prayers
Old Oct 16, 2018 | 02:26 PM
Brewmany's Avatar
Brewmany
Trickle charger or Maintainer/Battery Tender?
A true trickle charger puts out current the entire time it's plugged in and connected to a battery. It will continue to charge until it's unhooked, cooking the battery in short order.
A battery tender type charge will only charge when the battery needs it, shuts itself off, etc....
Old Oct 16, 2018 | 05:35 PM
doghead's Avatar
doghead
https://www.hdforums.com/forum/new-r...nner-code.html
Old Oct 16, 2018 | 06:47 PM
slapshot12's Avatar
slapshot12
Replace the battery. I've already had to replace mine, '15 and always on a Battery Tender too. A battery can still have good voltage, but fail the load test.
drew4jan
2014-2024 Touring Models
May 1, 2018 07:20 AM
T Man
Oct 21, 2016 06:40 AM
cpudoc
Apr 7, 2015 11:18 AM
STARRY
Jul 18, 2013 10:41 PM
gramps50
Jul 7, 2008 07:40 PM
