Gear shifter problems
Old Oct 29, 2018 | 07:29 PM
F150HD's Avatar
F150HD
First pic, its common for this to strip, there's an allen bolt on the backside, see if its tight.
Second pic is my 2012 Ultra, this is the inner shift lever behind the primary. The allen bolt should be tight. You can shine a light down there to peek at it & jiggle it. Issues arise when this isn't tight on the transmission shaft it mounts on.
Third pic, some folks have issues w/ these breaking, search the forum for Heim Joint and read up on the conversion.
Old Oct 29, 2018 | 07:40 PM
Screamin beagle's Avatar
Screamin beagle
Shift lever return spring. If you have to go inside don't overlook that.
Old Oct 29, 2018 | 07:54 PM
Studlintsean's Avatar
Studlintsean
Just had issue #1 and 3 on my 2011 FXDB. Replaced everything this weekend. Getting that shift lever on the spline is a pain in the rear with very little room to work.
Old Oct 29, 2018 | 08:40 PM
CSMHOG's Avatar
CSMHOG
Originally Posted by Mr. Mike
The guy is happy to have joined the “community”. Hopefully he gets his shifter issue sorted out.
Sorry, seems like another troll to me.
Old May 12, 2020 | 05:00 PM
Hodado's Avatar
Hodado
Default Stripped rear shift lever
On my 2002 RK the rear shift lever is stripped my question is should I replace with the stock part or go with the “Better Lever” I’ve seen advertised.If I’m just going to have it loosen up all the time using the identical part that fails I’m thinking the over priced “Better Lever” would be the way to go
If anyone has had experience with either method to repair this issue please advise and thanks for reading
Old May 13, 2020 | 05:29 AM
timbo141's Avatar
timbo141
Baker also makes a lever, much better price too.
https://bakerdrivetrain.com/collecti...nt=23522349379
Old May 13, 2020 | 08:39 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The prices on those "Better Levers" levers is crazy.
I think a lot of people buy these levers because they think removing the inner primary cover is too big of a job.
It`s just a screws, bolts, and gaskets, nothing complicated at all.
Make sure the splines on the shaft are not damaged.
As long as you keep the bolt in the lever tight, the oem lever is fine, just check it as part of your routine maintenance from now on.
How many miles are on the bike?
Old May 13, 2020 | 04:03 PM
Sporty302's Avatar
Sporty302
Shift levers on the transmission shaft are softer metal than the shaft itself so when the lever loosens its splines wear and the shaft spines are usually in good shape. Depending on year of bike the primary assembly might have to come off. Had to remove the primary assembly on my son's 2002 RK to replace the shift lever, but my 2011 FLHTCU has an indentation on the back of the inner primary cover that allows for the lever to be loosened, removed and replaced without removing the primary assembly. Not sure which year that change was made, but it sure makes for an easier repair.
Old May 13, 2020 | 05:34 PM
Hodado's Avatar
Hodado
The Baker looks like a good quality lever but the only way to use that one is removal of the cover I don’t think it would clear the casing to install
Damien Morrissey
Sep 10, 2019 12:49 AM
pd76
EVO
Sep 18, 2011 01:58 PM
King Cobra
Nov 10, 2009 09:29 AM
Compo48
Apr 26, 2008 01:09 PM
skos
Apr 19, 2006 01:54 PM
