Has anyone extended there gear shift lever?
Old Apr 18, 2006 | 02:46 AM
skos's Avatar
skos
Default Has anyone extended there gear shift lever?
I would like to move the heal shift back about 1”. Was @ HD & they only sell one from “drag” that moves it 2.5” & it about $80.
Looking for about an 1”
Any ideas?
Old Apr 18, 2006 | 08:32 AM
Mitt's Avatar
Mitt
Default RE: Has anyone extended there gear shift lever?
On my last RK I took the heal shifter off completly don't know if I'll do it with this one, probably will - when I get annoyed enough.
But I forgot about the piece someone sells to put over the space left by taking off the heal shift lever - anyone???
Old Apr 18, 2006 | 08:42 AM
flowerking's Avatar
flowerking
Stage I
Check out EZshift. I put the EZbrake on my new bike and it is all the difference for my big feet. I can now utilize the entire board. The shifters move forward 2" and back 1". This allows you to set the heel shifter very low as well as giving you all the board for your feet. Shifters will be my next investment.
http://bellsouthpwp.net/e/z/ezbrake/index.htm
Good Luck,
flowerking
Old Apr 18, 2006 | 10:57 AM
KBES BAGGER's Avatar
KBES BAGGER
Just cut it, and section in a new piece to make it longer. Weld her up, grind her down and call it a day. Atleast that's what I would do if it were me.
KB
Old Apr 18, 2006 | 01:12 PM
ScooterGuitar's Avatar
ScooterGuitar
Mitt,
Something like this?
http://www.jpcycles.com/productgroup...3-5E6FC6599985
I have seen different ones, I htink even HD has one to cove rup that area if you lose the rear arm.
Old Apr 18, 2006 | 05:25 PM
skos's Avatar
skos
OK wiseguy (KBES BAGGER) however I like how you think. My problem is I do not own a Welder. How bout you do this to yours, send it to me, & I will send you mine??
Old Apr 18, 2006 | 11:54 PM
KBES BAGGER
ORIGINAL: skos
PM me your shipping adress and tell me how much longer you want it. You will have to have it chromed though. However dont send me your's I have 6 stock ones laying around with no use for them.
KB
(P.S.) If you are serious so am I.
Old Apr 18, 2006 | 11:59 PM
05RK's Avatar
05RK
Check out this site, I think they have just what you are looking for.
http://www.shop.softbrake.com/Harley...hift_lever.asp
Old Apr 19, 2006 | 09:22 AM
Mitt's Avatar
Mitt
Thanks for the info on the shift cap for $16.00 - sure beats $44.00 for the other one talk about a RIP OFF...[:@]
Old Apr 19, 2006 | 10:38 AM
doch4m's Avatar
doch4m
skos,
I added the Walters Workshop extended shift lever in the dealer's parking lot before I rode my bike home. In my test/demo rides, my 10 1/2's didn't quite fit in the stock set up.
Personally, I love the heel/toe set up. I got used to it quick. Just needed a little more room. The Walters lever looks just like stock, but is 2 1/4 inches longer. I put it in the rear (heel) position. Looks great, works great.
The walters lever is about $80. They were great to deal with, and gave me some tips to make it an easy install.
www.waltersworkshop.com
Ride safe.
Doug
Slideshow: Harley-Davidson's new RMCR concept revives the caf racer formula with modern hardware-and it may be exactly the reset the company needs.
