0132 code
Old Oct 28, 2018 | 03:39 PM
leachman's Avatar
leachman
Default 0132 code
I have been getting a p0132 code recently, no red check engine just an occasional cough on acceleration. Started checking codes and this is only code I got. So as has been mentioned here on some forums this is a issue of high voltage with o2 sensor particularly with the front sensor. After investigation I found that when one of my (wonderful)l... Harley dealers I use diagnosed a bad fuel injector about year and half ago they for some reason took my power commander plug in diodes that come with the set up out of the wire connection that would normally be connected to the o2 sensor and just reconnected up wires as they come stock to the bike. In other words reconnected the o2 sensor wires back to stock....My bike is a 2008 ultra with 255 cams a power commander 3 fuel management with now fuel moto exhaust slip-ons i use to have Rinehart slip-ons. The bike has been dyno tuned professionally by Rob's Dyno in Gardner Mass. I found the diodes buried in my tour pack as that is where they put them and I didn't know that.....so as you may have guessed I put everything back the way it was suppose to be per the instructions from Dynojet power commander. Guess what? code went away....bike seems more responsive. Anyway if this may help anyone with same issue hope I have helped.
jbmss
Oct 29, 2012 05:11 PM
edjack
Apr 1, 2012 04:32 PM
DPete
Aug 11, 2011 03:44 PM
Skyking75
Mar 15, 2010 08:02 PM
FX4
May 2, 2008 09:59 AM
