What's this terrible sound?
Old Nov 3, 2018 | 04:34 PM
Torpedo1's Avatar
Torpedo1
Default What's this terrible sound?
Road King makes this loud sound at start-up sporadically, sounds pretty crappy. I also compared to my street bob and there's a real loud whine from the primary.
Am I looking at a compensator issue or is it something else?
https://youtu.be/YdF9o4wKYF4
https://youtu.be/CEiN20JHmHc
Old Nov 3, 2018 | 06:16 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Have you checked the level of the primary fluid lately?
Old Nov 3, 2018 | 06:32 PM
Torpedo1's Avatar
Torpedo1
It was just replaced and comes to right at the bottom of the clutch, took about 34 ounces. Prior to that though, im not sure the previous owner was changing it regularly.
Old Nov 3, 2018 | 06:44 PM
Kingglide549's Avatar
Kingglide549
I would pull your primary and look, but i can't reach it from here.......
So You pull it and tell us what you see and we will all go from there.
DaleMc0622's Avatar
DaleMc0622
I would start by checking the teeth on the starter and the starter gear inside the primary, almost sounds like it is missing a tooth or 3. Could be a compensator issue but mine sounded like it was rattling when it needed replaced. I would definitely pull the primary cover and look at teeth on the gears and starter real close.
Old Nov 3, 2018 | 08:23 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
I too would be pulling the primary cover and looking at the starters teeth and the matching teeth inside the primary. Highly unlikely, but check the gear reduction in the starter motor itself too.
Old Nov 3, 2018 | 08:24 PM
Kingglide549
Pretty sure it is the bendix
Old Nov 3, 2018 | 09:43 PM
bikerlaw's Avatar
bikerlaw
I just went through this with my Road King.
It turned out to be the compensator. $700 later she's all good.
Freakin' Harley and their bullsheet parts. Maybe that's not your issue, but it's a possible starting point.
Old Nov 4, 2018 | 12:00 AM
IKnowNot's Avatar
IKnowNot
OK, so we know it is a Road King.
What year bike?
What mods have been done?
Who’s bike is this?
How much of the above do you know?
What has been done to attempt to fix it?
From the videos it sounds like there is more then one problem here.
That annoying wine is not your compensator. Maybe the IPB? Or overly tight primary chain?
As for the start problems and sounds, it could be several things, including but not limited to a weak battery, worn starter, bad ground, bad compensator, or even a bad tune, or any combination of the above.
A little more info may help, or is this a test?
Old Nov 4, 2018 | 03:43 AM
Kingglide549
Just pass me the envelope ...
