2014 twist grip sensor
Old Dec 4, 2018 | 08:01 AM
Earl Nosis Bruce's Avatar
Earl Nosis Bruce
6th Gear
Default 2014 twist grip sensor
Just wondering if anybody knows the PART# or a online shop that sells twist grip sensor for a 2014 street glide changed bars and started throwing codes at me and I can’t find one for 2014 I’ve only been able to find up to year 13
Old Dec 4, 2018 | 09:30 AM
mmesa005's Avatar
mmesa005
You can connect on-line with Surdyke and confirm the part number listed below fits your bike.
32305-08B https://www.surdyke.com/
Old Dec 5, 2018 | 02:53 PM
langwilliams's Avatar
langwilliams
do you still have the "green connector" inside the handlebar? That seems to cause a lot of headaches....Since you're thinking of ditching the old sensor anyway you can try to bypass that extra connector an hard wire it. I had this happen to me when I changed bars an moved all the wiring inside the bars.
https://www.roadglide.org/24-control...al-wiring.html
if you do bypass the connector watch which wires you connect...there's 2 of each color wire from the twist sensor...half are in a yellow wrap/sleeve an half are in a black wrap/sleeve
Old Dec 5, 2018 | 07:11 PM
whocares's Avatar
whocares
You can Get the one used on the cvo's.it doesn't have the green connector.i believe it goes for approx $100.
Old Dec 5, 2018 | 09:13 PM
langwilliams
I looked into the CVO sensor for this reason but I read somewhere they have the wrong pins in the connector...I think they are female at the end of the wire an the plug they plug into is female also so you have to cut all the female pins off buy factory male pins an the clamping tool or have a tech at the dealership clamp them for you. if this isn't correct I'll change over to the cvo twist grip next time I'm messing with the wiring for something.
Old Dec 5, 2018 | 10:39 PM
whocares's Avatar
whocares
Just change pins and plug.its not that difficult .
trace2008
Jun 16, 2015 10:02 PM
Northbound Southerner
Dec 11, 2013 09:34 PM
redglider1980
Feb 6, 2013 12:27 AM
gtrplyr
Jul 30, 2010 11:00 AM
woosh
May 19, 2010 04:26 AM
