brake bleed help ?
Old Dec 17, 2018 | 09:21 PM
blue bronco's Avatar
blue bronco
Default brake bleed help ?
I am putting new bars on and got the new brake line from abs to master and tryin to bled brake using a syringe to to push the fluid and fill master and cant get the fluid to
move. I filled the syringe with fluid and put it onto the front bleeder screw the opened the bleeder and I cant get the fluid to move. like nothing is going in i am pushing the plunger and nothing happens. Help
Thanks
2018 sgs
Old Dec 17, 2018 | 09:54 PM
GalvTexGuy's Avatar
GalvTexGuy
I may be wrong, but you probably need to move the fluid from the master cylinder through the ABS module to the calipers instead of going from the calipers through the ABS module to the master cylinder. You'll need a Mighty Vac or something similar. This is all guesswork on my part since I've never replaced a brake line before. I've only flushed the brake fluid and that's the procedure and tool I use.
Old Dec 17, 2018 | 10:15 PM
sixguns's Avatar
sixguns
Thanks
2018 sgs
This is a proven method when replacing a line for a bar swap as it wont introduce any air into the ABS module. cap off the MC and bleeder open sufficiently to pass fluid? Once the air bubbles stop in the MC your golden. weird its not working, bleeder not drilled? connected to the right side caliper? ( note ) When you open the bleeder, you will get some air bubbles raise into the syringe, flicking the syringe with your finger until all the bubbles are gone,only then its safe to inject the fluid.
Old Dec 19, 2018 | 08:02 AM
fordhd2005's Avatar
fordhd2005
When you "fill the syringe", are you not pulling the fluid into it? If you are filling the syringe by taking the plunger out and then get air between the plunger and the fluid, it's very difficult to push the fluid through. It will go, just slowly.
Old Dec 19, 2018 | 11:59 AM
DanHappy's Avatar
DanHappy
I did it the same way (filled the syringe and the hose) and opened the bleeder up and squeezed. I was expecting it to take longer but it didn't! I had it spraying out all over the place!! Good thing I had it all covered...
Old Dec 19, 2018 | 10:53 PM
blue bronco
My bad I had a small piece of cardboard wedged under brake lever handle ( its used a shim per the instructions for replacing grips ) that I forgot about. I removed it and every thing went as planed.
Old Dec 20, 2018 | 06:08 AM
multihdrdr's Avatar
multihdrdr
Yeah ... that will do it ... everytime
jwnusbaum
Jul 5, 2020 03:32 PM
hardheaded
Jul 9, 2018 06:13 AM
lewk
Feb 9, 2018 12:14 PM
dawg
2014-2024 Touring Models
May 1, 2016 09:33 PM
Gunnysgt
Aug 23, 2014 11:28 AM
