I ordered a set of used 14 inch prewired bars online from a individual and it was suppose to come with extended brake line and clutch cable. The clutch cable has some minor damage and the brake line isnt correct. i kinda regret buying the bars now but i knew i was taking a chance, so its my fault. My question is can some send me a link to a extended front upper brake line for a 2010 street glide non abs with duel front brakes. I just need the extended top line but everything i found online is for the entire front setup. I also found a clutch cable that is 72 11/16 inches long and was wondering if that would be long enough for 14 inch bars?
585-381-8380 or Toll Free (877) 564-8248. We might be able to help with a new cable and upper brake line depending on the connection. I would measure just to be sure. Could you send me an image of the connection to the lower brake? We might be able to come up with a solution. info@magnumshielding.com
I believe im gonna have to replace the entire front brake line all the way to the calibers. I dont have my bike back yet from shop to check but I believe its stock lines. Its getting repaired from a crash. Im planning on doing the install once I get in back and just wanted to have everything I needed.
The shop might measure for you in that instance. Hope you weren't injured.
ok thanks. I wasn't injured to bad. I just ended up with sprained ankle and fractured foot with some road rash. I was more upset about my bike. A drunk driver pulled out in front of me at last possible moment.
