Changing Rocker Boxes
Old Mar 2, 2019 | 08:47 AM
  #41
skydude426's Avatar
skydude426
Originally Posted by miketv84
Do you recommend buying the rocker box wrench for the bolts ?
I have one after doing this job on a previous bike. It is handy but certainly not necessary. I also cut down a 3/16” Allen wrench which works on the rear cylinder.
I have since replaced my rocker box cover bolts with chrome Allen head bolts. That’s a different home made tool for those.
Old Mar 2, 2019 | 10:23 AM
  #42
ew25950's Avatar
ew25950
How are you guys torquing those bolts back on with the tight clearance while the motor is still in the frame?
Old Mar 2, 2019 | 12:57 PM
  #43
dawg's Avatar
dawg
This is where the small dogbone torque adapters come in handy.
Old Mar 2, 2019 | 01:17 PM
  #44
skydude426's Avatar
skydude426
That 👆
Old Mar 2, 2019 | 03:17 PM
  #45
ROCKOUT Rocker Products
Sponsor
If you run into clearance problems using the dogbone adapters, turn the torque wrench upside down. Took me an embarrassing amount of time to come to that realization
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Mar 2, 2019 | 03:22 PM
  #46
miketv84's Avatar
miketv84
What setup do you have there? Wr3nch and socket size?
Old Mar 2, 2019 | 03:51 PM
  #47
Sponsor
These are the two sizes typically used, both 3/8 drive & both were purchased on Amazon
Old Mar 2, 2019 | 03:53 PM
  #48
miketv84's Avatar
miketv84
Cool thanks. Going to purchase. And the socket ?
Old Mar 2, 2019 | 04:00 PM
  #49
hattitude's Avatar
hattitude
Get something like these....
Amazon Amazon
If you get the full set, you will use them in many places if you regularly work on bikes and cars... they can be used with a 3/8" torque wrench (use at 90° from wrench for proper torque), or with any 3/8" drive as a way to get into/at low clearance bolts.... can be very handy... especially for a low clearance bolt that should be torqued...
Old Mar 2, 2019 | 04:11 PM
  #50
fdesa's Avatar
fdesa
I recently installed the Rockout inserts and these are the 2 tools I bought from Amazon based on John's advice. They came in very handy for those hard to reach bolts and for proper torquing values 👍
