2014 RG wont start after alarm is disarmed
Old Mar 9, 2019 | 11:19 AM
Morton Williamson's Avatar
Morton Williamson
Stage IV
Default 2014 RG wont start after alarm is disarmed
The starter switch is non responsive after the security system is deactivated. Got lights and behaves as if security system has been disarmed. It will start only if the main fuse is removed and then reinserted. it will run and restart as long as the security system does not arm. If it arms I have to remove and replace the main fuse to start it. It behaves the same way with either the key fob or the pin-code is used to disarm the security system.
Anyone ever seen or experienced this?
Old Mar 9, 2019 | 09:09 PM
Mr. Mike's Avatar
Mr. Mike
Mort,
If the error codes are cleared, try your scenario again and see what new code(s) pop up. Certainly sounds like a T$$M issue to me, but you never know.
Old Mar 15, 2019 | 03:31 AM
Morton Williamson
Stage IV
Mr. Mike,
Fault number: B1123HFSM left turn lamp (Hands free security module)Short circuit to groundIntermittent faultHistoric faultFault number: B1131AlarmOutput Shorted to GroundPermanent faultCurrent faultFault number: U1300Serial data busShort circuit to groundPermanent faultCurrent faultIm thinking about taking it to an Auto electric shop so that they could help locate the shorts......I believe that would be the most expeditious route...what do you guys think???
Old Mar 15, 2019 | 12:35 PM
batman.'s Avatar
batman.
can you remove the alarm fuse or take the alarm out period and see what it does? sounds like its internal to the alarm itself
Batman
Old Mar 26, 2019 | 02:12 AM
Morton Williamson
Stage IV
Default Update
Problem resolved...
Battery was putting out 6V instead of 12V.....
Replaced battery
Loose Battery connections
Cleaned and applied dielectric grease to terminals
Thundermaxx ECU failure
Swapped in Stock ECU.....starter/HFSM issue remediated
The Thundermaxx failure resulted in driveability issues. The maint port is non responsive and in service the Thundermaxx triggered the BCM , SDPO, and RAD DTCs. It could very well be that the firmware is corrupted due to the low voltages the battery supplied.... I'm going to reach out to Thunder tomorrow to service or replace the failed unit.
Thanks everyone for your help/input...
Dolce
Electrical/Lighting/Alarm
Jun 8, 2016 08:03 PM
nightrider33
Oct 26, 2015 07:03 AM
flyboyron
May 2, 2014 10:09 AM
KiloGolf4
Aug 26, 2012 06:10 PM
Roadie4
May 27, 2007 08:51 PM
