I have a 1510 code safe mode. How do I remove it
Old Mar 14, 2019 | 01:51 PM
anthonyzx10r@yahoo.com's Avatar
Default I have a 1510 code safe mode. How do I remove it
2010 Electra Glide classic. There was a problem with the electronic throttle control and the computer entered a "safe" mode. This mode enables near normal performance but watches for unintended wide open throttle. P1510. I have replaced the ETC but can't turn off the sare mode . Please help and Thank you ..
Old Mar 14, 2019 | 02:31 PM
5280Ruffian's Avatar
5280Ruffian
You need a code scanner, as far as I know. I have the FP3, and that allows me to clear codes.
Old Mar 14, 2019 | 02:59 PM
hbsoldier3's Avatar
hbsoldier3
You do not need a code scanner. Just run the diagnostic check per your service manual and clear the code.
Old Mar 14, 2019 | 04:31 PM
Default I have a scanner FP3 and I have tried clearing from speedo
I do have a scanner FP3. This is why I know about the 1510 code . It doesn't show up on the speedo scan. I can clear all codes with FP3 but won't clear the 1510 I have done resurch and hears there is a process you have to go through to clear it I can't find it just wondering if somebody else knows about it thanks
Old Mar 14, 2019 | 04:33 PM
yes I have a FP3 but it won't clear this code and this code don't show up on speedo scan . I hear there's a process you have to go through to clear this code I haven't been able to find it
Old Mar 16, 2019 | 11:16 AM
Default Any help
Someone has to know how to delete the code
Old Mar 16, 2019 | 12:33 PM
barneyboy's Avatar
barneyboy
Do a search on "throttle reset", the pocededure involves cycling the ignition/kill switch. I've seen it here, but can't recall where exactly. Might be worth a try.
Old Mar 16, 2019 | 02:21 PM
Default Thank you
[Perfect thanks you QUOTE=barneyboy;18109630]Do a search on "throttle reset", the pocededure involves cycling the ignition/kill switch. I've seen it here, but can't recall where exactly. Might be worth a try.[/QUOTE]
Old Mar 16, 2019 | 02:47 PM
doghead's Avatar
doghead
https://www.hdforums.com/forum/exhau...-throttle.html
Or search this forum for "1510 code", there are 30 threads on it.
Old Mar 16, 2019 | 09:53 PM
Default Thank you
I will any help is great
Wolvie66
General Topics/Tech Tips
Jun 11, 2019 08:12 PM
nectsta
Jul 27, 2013 11:51 AM
anicely
Feb 9, 2013 09:17 AM
Hoosier XLC
Mar 27, 2012 07:41 PM
toad6301
Oct 13, 2011 08:19 PM
