Wrong exhaust gasket??
Old May 6, 2019 | 06:33 PM
Zerk's Avatar
Zerk
I keep using the standard exhaust gaskets. It looks like there is nothing to the SE, not tappered. Maybe there is a reason for this, i am not a gasket pro. Not really sure if you need a high performance gasket on the heads. But like I said maybe a reason.
Old May 6, 2019 | 08:27 PM
CookUltraClassic's Avatar
CookUltraClassic
I got them in finally. It was a pain in the *** though. Seems like I get to have a fight every step of the way...
I’ve had to weld an Alan to a ˝” wrench so I could 90° my torque wrench to get to rockers... grind down another wrench to get to the passing light nut....
nit to mention dropping **** into the black hole behind the starter....
i spend HOURS... and make creeping progress.....
ther being ssid.... I HAVE made progress. All that’s left is finish pipes, abd install outer fairing and oil and it’s time to go!
i hear bikes all day from my shop. Driving me crazy!!
Old May 7, 2019 | 05:01 PM
Zerk's Avatar
Zerk
1/4 drive ratchet is nice for exhaust bolts on heads.
Old May 7, 2019 | 06:17 PM
hattitude's Avatar
hattitude
You got the wrong gaskets..... but I see you have already figured that out and corrected the issue.
For future reference...
The Twin Cam engine, OEM exhaust gaskets are #65324-83B. They are thick, with a square side that fits into the head, and a slight conical shape that the head pipe fits into.
They are designed to crush and seal as the header is torqued into the head. They are designed to work best with any header that has a tapered flange/end to the head pipe, that fits into the exhaust port (like this twin Cam OEM head pipe)..
The Screamin Eagle Gaskets are #17048-98. They are 1/2 (maybe less) the thickness of OEM gaskets and are flat and square.
They are also designed to crush (albeit less than OEM) and seal as the header is torqued into the head. They are designed to work best with any header that has a square flange/end to the head pipe that fits into the exhaust port (this is a Buell head pipe for illustration).
Whoever sold you those original gaskets, needs to either pull their head out of their nether regions, and/or actually learn a little bit about the product(s) they are selling....
Good luck with your repair... looks like you are on the downhill side of it.... can't wait to read your report on how it runs when you get it back together...
Old May 7, 2019 | 06:30 PM
dawg's Avatar
dawg
and then there’s copper crush gaskets
Old May 8, 2019 | 05:05 AM
CookUltraClassic
Progress is slow going. If it weren’t for that damn job of mine!! Ha it gets in the way of all my fun....
Old May 8, 2019 | 07:45 PM
danzio's Avatar
danzio
It's all this brother that makes the "job well done" so satisfying. When you're scrubbing the grease off your bleeding knuckles and the stream of hot water from the shower head soothes your aching back.............you can remind yourself that you just saved a bunch of $$ and you know the job is done.....right!
Old May 8, 2019 | 09:47 PM
QC's Avatar
QC
mike_oh
Sep 16, 2016 01:20 PM
F86
Mar 24, 2016 03:15 PM
jharanin
Dec 14, 2011 06:40 AM
mja52403
Dec 5, 2009 05:13 PM
rick180
Feb 21, 2008 07:17 PM
