Best and worst years for compensators?
Went to the Baker unit with new rotor. Also got rid of the HD ratcheting
tensioner. Replaced it with a SHB hydraulic unit.
It's been 2000 miles so far and is working good.
Forgot to mention. My bike is a 09'.
Harley switched to a new style compensator in 2006, first in the Dyna bikes. It was part #40296-06. It was different from the shovel head/ EVO/ early TC88 compensators. It had many problems. The Shovel head/ EVO/ early TC88 compensators were pretty much trouble-free in comparison.
They upgraded that initial compensator in 2007. The part was now #40296-06A. This was first redesign of the problematic compensators. There were many reports of compensator problems and failures with this one too........
They changed the OEM compensator, in 2011. It was now part #83935-09A. This was called the Screamin Eagle compensator and was an option, prior to 2011. It was much better than its predecessor, but still had reported issues and failures..
They went with an upgraded compensator again, in 2014. It was changed to part #42200064A. It became OEM issue on the '14+ bikes. That is the compensator that uses a deflector, to direct oil into the splines of the compensator. This version has proven to be the most reliable of the compensators, since they “upgraded” from the shovel head / EVO / early TC88 style compensator in 2006…
The 2014+ bikes have the defector built-in to the primary cover. If you want to add the newest compensator to an '07-'13 bike, you will need to glue the included deflector into the inside of your OEM primary cover, or buy a '14+ primary cover (at a cost of about $200).
They changed the compensator again, in '17, for the M8 engine bikes..... not sure if that was a redesign of the '14, or an entirely new concept & design ...
They went with an upgraded compensator again, in 2014. It was changed to part #42200064A. It became OEM issue on the '14+ bikes. That is the compensator that uses a deflector, to direct oil into the splines of the compensator. This version has proven to be the most reliable of the compensators, since they upgraded from the shovel head / EVO / early TC88 style compensator in 2006
It's a shame Harley doesn't offer oil deflector over the counter. Looks like I'll wait for my compensator to go bad, maybe by then Harley will have this compensator issue solved 100% .lol.
B Bop
2012 FLHR (Road King) Stage II Red Ember Sunglo/Merlo Sunglo, Original HD Chrome Laced Profile Aluminum Spoke Tubeless Rims, ABS, Cruise Control, Security Package, Saddlebag LED Spoiler lights, and array of nostalgic & performance accessories that enhances appearance & blood curdling performance.
