Best and worst years for compensators?
Old Jul 7, 2019 | 03:44 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
My 2011 was in the shop a while back for abs module replacement (Warranty) and the tech had my comp bang on Him at startup, so He replaced it. He said an updated one was available and much better. Warranty covered. Replaced, and all is fine.
Old Jul 7, 2019 | 07:22 PM
hattitude's Avatar
hattitude
Your bike came new (OEM) with the #83935-09A compensator (formerly Screamin' Eagle Compensator).... The tech switched you to the upgraded "Rushmore" compensator, #42200064A, with the deflector that directs oil into the compensator. It is the least problematic of the newer Twin Cam compensators.... some have had issues, but certainly not the number of failures with prior "upgraded" compensator versions....
Old Jul 8, 2019 | 05:26 AM
N1265's Avatar
N1265
Is the only difference in the #83985-09A and the #42200064A the oil deflector ? or is it a totally different design ?
Old Jul 8, 2019 | 09:12 AM
hattitude's Avatar
hattitude
Not a totally different design, but there were some good changes made, in addition to the oil deflector....
Old Jul 8, 2019 | 12:54 PM
N1265's Avatar
N1265
Many Thanks for posting this, right now I just have a couple of questions :
1) What is the number of the service kit to upgrade previous models ? ( Mine is a 2011 FLHTK )
2) Looks like you could add the kit without pulling the inner primary, clutch pack and rotor, If this is correct what would you gain ( except lubrication ) buy just adding the kit to a used clutch pack ?
( Would it tighten the compensator up enough to justify the cost / work )
3) Has there been any problems with that retainer clip falling off and causing damage ?
Old Jul 9, 2019 | 10:50 AM
hattitude's Avatar
hattitude
It is listed in the Harley parts catalog, and will also list the fitment.....
Clutch pack and compensator are two totally different things with two totally different jobs..... their wear & replacement are not related to each other... On some years you need to change out the rotor, I believe you are OK with a 2011, but the instructions will tell you for sure...
Retainer clip...? If you're talking about the way the deflector is added to a pre-2104 outer primary cover, I have not read/heard of any issues.... You could always buy a 2014+ outer primary cover for you bike, it will have the deflector built in to the cover...
See answers in red above.....
Old Jul 9, 2019 | 12:35 PM
N1265's Avatar
N1265
" Clutch pack and compensator are two totally different things with two totally different jobs..... their wear & replacement are not related to each other... On some years you need to change out the rotor, I believe you are OK with a 2011, but the instructions will tell you for sure... "
My bad, I meant to say spring pack instead of clutch pack .
Many Thanks for the info .
Old Jul 9, 2019 | 12:46 PM
SBates08's Avatar
SBates08
Originally Posted by 67Shuv
My ‘13 is around 45K miles and sometimes I think I hear it on startup and shutdown and other times I don’t. When it’s time for mine to be swapped, I’ll put an eliminator in it and roll on. I get the purpose of the compensator but none of my old bikes had them and they’ve gone down the road for decades upon decades just dandy.
Exact route I'm going as well. Vulcanworks Comp Eliminator, Baker Armored Attitude Adjuster, Jim's shifter shaft seal, and an All ***** IPB all sitting on the work bench awaiting install. 60,000 miles on original 2010 Comp on a FM107 was pretty good I suppose but once the Eliminator goes in I'll never have to worry about a Compensator again.
Old Jul 9, 2019 | 08:11 PM
hattitude's Avatar
hattitude
There is a process to measure and shim the spring pack to increase preload on the springs and quiet a "loose" compensator. I've never done it, but read about it...
From Joe Lyons, a really good tech who owns a shop in the midwest:
"Talked to tech services yesterday and they have a new procedure for noisy comps that some people have ran into. The complete compensator will need to be removed and as it is assembled sit with the large hex facing down on the table. The depth from the top spring to the spline adapter is what needs to be measured. The spec. is .286"-.326". If it is less than .286" then there are spacers that can be used to add more preloaded. These spacers are .031" each and I believe a max of two can be used but possibly 3. The spacer PN is 1030021."
ElectraLarry
11
Jul 10, 2025 10:04 PM
1BADHD
Feb 27, 2012 04:51 AM
crazzy76
Jun 29, 2011 06:17 PM
davessworks
Sep 19, 2010 01:44 PM
2WheelGlider
Aug 15, 2010 07:51 PM
