Lowering Ultra
Old Jul 8, 2019 | 02:14 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
I've got the Prog. 944's HD on my Road Glide Ultra, those shocks are 12" height but ride like a 13" shock. I had Mean City Cycles modify my seat. I can flat foot, but the concern I have and it might affect you is the jiffy stand is stock and it appears the bike doesn't have the lean on the jiffy stand like it did when the rear shocks where stock. I'm considering buying a jiffy stand from an Ultra Low.
Old Jul 8, 2019 | 10:11 PM
flashprez's Avatar
flashprez
Originally Posted by bundy43
so you are still running 13 inch air shock, correct.
Yes still running stock air shocks.
Old Jul 9, 2019 | 03:02 AM
ramblin5's Avatar
ramblin5
Put the Ultra Low seat on. That will give you another inch without lowering your boards.
Old Jul 9, 2019 | 05:40 AM
DonnieM's Avatar
DonnieM
While it is not the preferred method, I used a Pingel 1" lowering kit on my Ultra and have not experienced any problems at all. The kit has been on there 3 years and just this month checked out the bolts, shocks, etc with them being fine.
Old Jul 9, 2019 | 06:13 AM
bundy43's Avatar
bundy43
OP if your scrapping your boards now, I would not suggest lowering it any further . Lower seat, or thicker sole boots.
Old Jul 9, 2019 | 06:25 AM
PFWiz's Avatar
PFWiz
This, except I used Ohlins from Motorcycle Metal along with brackets set to the smallest drop and Progressive -1" Monotubes up front. I got the Harley wedge that changes the angle of the jiffy stand to make it effectively shorter.
wood86
Sep 7, 2017 02:56 AM
foxtrapper
Jan 12, 2013 12:00 PM
Mi3ninos
Nov 11, 2011 10:38 AM
brino
Nov 5, 2010 10:39 AM
whodares
Oct 20, 2010 08:02 AM
