Cam recommendations for 2006 Stock head 88 ci tc touring
Old Aug 10, 2019 | 01:11 PM
Reeddog's Avatar
Reeddog
1st Gear
Default Cam recommendations for 2006 Stock head 88 ci tc touring
Hello gents i was looking forward to upgrading my cams to gear drive . Would anyone be able give advice on this from past experience. I would like to go for a good low end cam that gives best results for a stock 2006 88 tc heads. The only mods i have is a kn high flow , vance and hines 2-1 pro pipes and the notorious fuelpak. Thanks for any info.
Old Aug 10, 2019 | 03:08 PM
robarosa's Avatar
robarosa
Until someone comes along, there's some cam discussion in the Engine Mechanical section for the TC88 right now to check out. Here's one.
https://www.hdforums.com/forum/engin...am-help-2.html
hth
rags's Avatar
rags
Andrews 21 is a good choice.
Old Aug 10, 2019 | 05:15 PM
booze hound's Avatar
booze hound
I just upgraded to S&S 509 gear drive cams and I'm pleased with the results. Throttle response is much crisper than stock and made the bike more fun to ride overall. I wish I would have done this upgrade years ago. Good luck!
Old Aug 10, 2019 | 06:24 PM
Tired's Avatar
Tired
What's your runout measure?
Old Aug 10, 2019 | 08:08 PM
EG-2006's Avatar
EG-2006
I did the Andrews 21 and a dyno tune on my '06 electra glide and was very happy with the results.
Old Aug 10, 2019 | 08:40 PM
Reeddog's Avatar
Reeddog
1st Gear
Im not sure what the run out is . It only has 6000 miles on it.
Old Aug 10, 2019 | 10:32 PM
hattitude's Avatar
hattitude
He asked about your run out, because you need to have .004" or less (some say .003" or less) run out before you can use gear drive cams.... and run out over .004" will eventually ruin the gear drive cams, they will self destruct, and you'll have serious issues....
Mileage is irrelevant. Harley had issues with run out numbers, from about 2004 on..... they kept changing the run out spec, rather than fix the problem... They increased it two or three times over the years... I believe they got as high as .012" for "allowable" run out.... any machinist will tell you that anything over .004 isn't good.... it's only acceptable, because Harley says so.... I'm sure they went this route for a low cost way of limiting warranty crank issues.
That's the reason why many big bore, late model, twin cam builds have their cranks balanced and welded before going over 120ish HP... Hoban Brothers, DarkHorse Crankworks says, "We true all crankshafts to within .0015” total indicated run-out at each main bearing race and guarantee them to stay within .0005” for 2 years and unlimited miles."
Anyways, there is a good chance your 2006 has too much run out, right from the factory, to allow for the use of gear drive cams..... makes sure to measure before you order the gear drive cams...
Good luck with your mods....
Old Aug 11, 2019 | 01:41 AM
bklynbob's Avatar
bklynbob
Save the money on the gear drive and use it on a set of flat top se pistons. I guarantee you’ll appreciate your new cams a lot more.
Old Aug 11, 2019 | 10:07 AM
EdwardK's Avatar
EdwardK
To add a little to the great info Hattitude said, the run out is a measurement of the the end of the crank. The stock cranks rarely turn perfectly true. They wobble a little measured with a dial indicator.
Get a new cam plate with hydraulic tensioners. They will last 100,000 miles easily and increase your cam choices. Gear drive are also louder.
Cam choices are personal preference and riding style. For consideration, look at SE204's for a good low to mid rage cam with lots of torque. I think they were originally designed for an 88 and I have them in a 103 and love them. They can grow with your build if you bump up later. Everyone, like me, is going to tell you the cam they have and like. They may or may not be good for you if your riding style or needs are different than theirs. Do your research and if you are going to have an indy install. tell them how you ride, what you want out of a cam and they can make suggestions.
Good luck.
