06 RK shift shaft pawl assy replace
Old Aug 18, 2019 | 04:37 PM
Fritz Franz's Avatar
Fritz Franz
Default 06 RK shift shaft pawl assy replace
can the shift shaft (pawl assembly) be replaced with trans in the bike? I'm about to replace the shift shaft lever second time since getting the cop bike, now has 60K mi. If shaft splines are worn, I want to replace shift shaft new. My manual isnt clear about sequence of disassembly.
Old Aug 18, 2019 | 08:11 PM
Am4wag's Avatar
Am4wag
Gotta pull the trap door/gearset(s).
Old Aug 18, 2019 | 08:48 PM
cncmike's Avatar
cncmike
Check the teeth closely. I don’t think they honestly go bad. I’m not sure about your year but my ‘09 shift lever is aluminum so there’s no way it can wear the steel teeth on the trans. After trying three new levers I found a way to make them fit tighter and I’ve never had a problem again. I took the lever and slipped a hacksaw through the slot on the side of the lever and cut into the opposite side of the lever about 1/8”. Then I put it in a vise and closed it down more than stock. Just to the point that I had to tap it lightly to get it on the trans shaft. Then I replaced the cap screw with a grade 8 hex bolt and tightened it as tight as I could. Of course I had the primary off when I did this. I don’t think the stock lever can be squeezed tight enough by the factory bolt alone.
DougW2000
Jan 9, 2019 08:02 AM
CT-Bagger
Sep 13, 2012 09:35 AM
pd76
EVO
Sep 18, 2011 01:58 PM
Hoblick
Aug 29, 2011 09:32 AM
PDDGM
Oct 9, 2008 04:42 PM
