2to1 tune question
Old Aug 26, 2019 | 09:44 PM
jt metal's Avatar
jt metal
Default 2to1 tune question
I had my bike Dyno tuned with powervision 3yrs ago, on decatted factory header. assuming I'm going to lose my original Dyno tune. question.......
If I switch to 2to1 pipe, what's the difference between calling fuel Moto and having them send me a new map vs another Dyno tune?
Old Aug 26, 2019 | 09:48 PM
paul1970's Avatar
paul1970
Fuel moto will get your bike running good and for most good enough, but in my opinion it’s just a starting point a dyno really dials it in
Old Aug 26, 2019 | 10:04 PM
hattitude's Avatar
hattitude
Are you only changing the exhaust....?? Do you own the PowerVision tuner, or did you just buy a license and have it tuned with the dyno operator's PowerVision tuner....?
If the dyno guy owns the PowerVision tuner, go back to him and let him dial it in. It shouldn't take too long to dial in the tune. The exhausts have different characteristics, but the tunes will be close, all else being equal... This would be the quickest and best (if you have a good dyno guy) option whether you own the tuner or not... but will cost some money
If you own the PowerVision, bought it from FuelMoto, and want to have a little fun.....
The tune you have now should be close to the tune you need... I would save a copy of your current dyno tune. Then I would use it to run a couple auto tune runs. Note how it runs with that new tune. Note where it's deficient, or you feel it needs some help. Then take it out and do some data logging. You can then send the tune to FuelMoto, with your changes, the datalog, and where you feel the tune is deficient. They will send back a better tune.... you can then try that tune and see if you can save the money on another dyno tune...
Good luck with your decision..
Old Aug 27, 2019 | 09:13 AM
jt metal's Avatar
jt metal
I own the tuner. And didn't want to spend an additional $500 on more Dyno time. I was hoping to continue with Dyno tuners tune.
Old Aug 27, 2019 | 02:13 PM
hattitude's Avatar
hattitude
Then I would suggest part two of my post... do some auto tuning and if not good enough, send data logs to FuelMoto with your needs....
Good luck....
Old Aug 27, 2019 | 04:16 PM
Bowhunter61's Avatar
Bowhunter61
You are going to want to do what Hattitude suggested if you are going from a stock header to a 2-1 pipe. I did the same thing on my 107 build and just needed to run several autotune sessions to find the delta's, from there I just ended up tweaking the maps until the changes in the autotune runs were minimal. But the original tune didn't run well with the addition of the 2-1, if I remember right the biggest change was to correct decel popping
fishn4life
Oct 2, 2020 01:15 PM
daytonhd
Jul 10, 2012 08:15 PM
jpalm
Nov 19, 2010 10:40 AM
Green Machine 04
Exhaust System Topics
Oct 2, 2010 10:45 AM
HOGRIDA_06
Apr 11, 2008 06:22 PM
