Primary Noise
Old Sep 9, 2019 | 10:41 PM
miketv84's Avatar
miketv84
Originally Posted by Salmo pass
When i bought the All ***** starter jack it came with a warning slip inside the sealed package about the already installed steel ball
Yeah no warning slip in mine. On top of that I had watched the fixmyhog vid which reminds you to take the old ball out and install it in the new one. Hence the mistake .
Old Sep 10, 2019 | 12:34 PM
Toe Knee's Avatar
Toe Knee
When you installed the all ***** clutch, did you add a ball bearing. it's super important NOT to take the one that's in the old set up and adding it to the all ***** clutch. there is already aberring in the new clutch.
never mind....you already got that.
Old Sep 10, 2019 | 02:03 PM
miketv84's Avatar
miketv84
Thanks though. Yeah had 2 ***** instead of 1 . Lmao. Anyways hopefully that will fix the leak too. If not new starter it is.
Old Sep 11, 2019 | 08:25 PM
Zerk's Avatar
Zerk
I hope not mine is already together. I interupted the picture different. Wasn't impressed with matchbook instructions.
MIne is still on the bench.
Old Sep 11, 2019 | 08:44 PM
Zerk's Avatar
Zerk
Stripped down to my underwear and went out and verified there was 2 ***** in my starter. Also the instruction clearly spelled it out. Glad I read this, and glad didn't finish other stuff.
Old Sep 11, 2019 | 08:47 PM
miketv84's Avatar
miketv84
Yeah also the 2 ****ing O rings are the same size in the kit so I had to order the inner one .
Old Sep 11, 2019 | 08:51 PM
Zerk's Avatar
Zerk
I replaced the inner oring. PIA. Debated doing it.
Old Sep 11, 2019 | 08:53 PM
miketv84's Avatar
miketv84
Yeah I reused the old one . Fml. Jpcycles was retarded in answering any questions about the O rings. Leak stopped but I still want to change it once I get it.
miketv84's Avatar
miketv84
Jpcycles was like , maybe they just sent you an extra of the outer one. Ummmmm no.
Hades02
Oct 11, 2017 10:40 AM
boothman
Oct 14, 2015 07:58 PM
dualplug
Shovelhead
Mar 28, 2010 09:28 PM
StreetGlider56
Aug 10, 2009 11:00 PM
96 Wide Glide
Dec 13, 2007 02:03 AM
