FYI, for anyone looking for bagger cams...
Old Jul 15, 2007 | 07:19 AM
BOARGAURD's Avatar
BOARGAURD
Default FYI, for anyone looking for bagger cams...
Okay guys and gals the deal is I was pleased with the 07 flht performance with the fullsac duals, older screamin eagle slip ons, screamin eagle air filter and a properly mapped pc III. However, I wanted a little more roll power will running around 70 mph so I searched for a good cam. I ended up selecting the Andrews 26H for the 07 96" motor, I also kept it a chain drive instead of changing to gear drive since I have read the tensioners and oiling system was a better design on the 07's. The Andrews comes highly recommended for baggers and 2up operation and start to pull about 1800 rpm. The S&S 510 cams tend to come on late at 3000 rpm or so, much later than I wanted in the cruise area. Others stated that Andrews 37s tend to ping a lot.
So, the only change to the bike ended up being the Andrews 26H cam period....
I had the pc map built for the bike yesterday at Sabins in Dallas and as Jim stated, "someone forgot to tell the bike it has new cams". The dyno numbers are pretty much the exact same, same curve. I only had, at peak performance, .3 hp and 1 torque point gain. But looking at the graph it has about a 3 point torque gain at 3000 rpm.
Am I upset, NO. I only have the cost of the cams, gaskets and a dyno into this small build/change ($350 total) and the numbers did not drop from original dyno back in Feb. I was wanting more but like I said in the beginning, I was not unhappy with the performance just was looking for a little more on roll on. The seat of the pants does feel different but that may just be the fact I know I put work into the bike someone else may not notice it. This is only info for the people searching a cam swap and what real numbers will bring comparing only the cam differences.
[/align]
Old Jul 15, 2007 | 07:30 AM
PapaTravis's Avatar
PapaTravis
Default RE: FYI, for anyone looking for bagger cams...
Looks like decent numbers to me, considering you didn't even go whole hog with a big bore kit.
Old Jul 15, 2007 | 07:41 AM
PhilM's Avatar
PhilM
hmmm...... that's quite interesting. [&:]
The only slight difference in the run traces is that the old run used a lower smoothing factor than the new run, which gives it a more bumpy look (vs. the smooth look of the new one) and the result is slightly higher numbers based on the "peaks". Even so, that may only be another one or two ft/lbs of torque.
I am very surprised at the results here.....[sm=confused06.gif]
Jason ~ What were the weather conditions like when ya did the run previously? I know it was hot & humid yesterday, as I all but melted cleaning my bike yesterday afternoon.
Old Jul 15, 2007 | 11:12 AM
Harleypingman's Avatar
Harleypingman
The numbers are very surprising; only 70 hp?
Ambient air temp will make a big difference. My friend, "pirateye" on this forum, tuned his HQ 95" motor in March in 60 degree ambient air, then tuned it again a few weeks ago in 99 degree ambient air temp and saw a 10 hp and torque loss--and he's an outstanding tuner.
Old Jul 15, 2007 | 11:19 AM
GliderXXX's Avatar
GliderXXX
No offense intended, but I can hardly see this as a reccomendation for new cams on a stock motor. Frankly I have never seen "just cams" do much for any stock motor, and this supports that even further. I don't know what the lift or duration is for the 26H's or the stock HD cams, but by this dyno chart, and due to the fact that Sabin know's what he is doing typically, they must be very similar.
Old Jul 15, 2007 | 01:06 PM
iclick's Avatar
iclick
ORIGINAL: BOARGAURD
[/align]
I've been looking into a cam change for my '07 SG and the 26H was at the top of my list, but this frankly doesn't encourage me much. The PCIII map I'm using now came from an identical bike--same mufflers, etc.-- and it shows five more HP and a longer torque curve, although peak torque isn't quite as high and comes in at a slightly higher RPM (3200). I've been talking to bob2002 via email about his Andrews 26G build, also a 96" engine, and he shows 85HP and 85TQ. I haven't seen his chart yet be he promised to email it to me later today.
Since I would like to see a low-end and mid-range TQ increase, I'm not seeing it play out in the two cases I've seen so far. HP is not an issue for me, as I rarely have the engine about 4k RPM's anyway, and I don't care who can out-drag me. I'm interested in how fast the bike can pass an 18-wheeler without downshifting.
What I would like to see now is a chart for a 96" motor with an Andrews 21H installed. It comes on quicker, with HP tapering off quicker as well, but I doubt if TQ would be higher than the 26H.
[IMG]local://upfiles/4327/7B231ADC9C6740BFAB75056C1AB210E2.jpg[/IMG]
Old Jul 15, 2007 | 02:07 PM
UltraKla$$ic's Avatar
UltraKla$$ic
I really appreciate you posting this info open mindedly.Enlightening on a cam only install.
Old Jul 15, 2007 | 03:04 PM
NCCopBikeRider's Avatar
NCCopBikeRider
Dyno Numbers can be anything the operator wants them to be. We run a Chassis dyno three Days a week for a Well Know NASCAR Race Team, and can give you any number you want.
Maximun numbers are entertaining to view, and argue about, however, trends are what we look at.
Ride Em Carry Em
Old Jul 15, 2007 | 05:44 PM
BOARGAURD's Avatar
BOARGAURD
ORIGINAL: GliderXXX
No offense taken, as I am not recommending this setup to anyone, to each their own. I just wanted to let the real numbers show. While the 26's have been proven in the 88 in motors, it is definatly different in the 96 in configuration. And I am not blaming anyone who recommended me to use them, but if I were to do it all again I would look into something else. When I decided on this cam it was all on hear say and could not find anyone who had just done cams alone in my configuration. Well, here are the numbers for what it is worth.
Old Jul 15, 2007 | 07:14 PM
GliderXXX's Avatar
GliderXXX
ORIGINAL: BOARGAURD
ORIGINAL: GliderXXX
Got it Boarguard and very big of you to do it!
